Ambilight Without Arduino for Non Addressable RGB Leds
4,366
50
6
Posted
Introduction: Ambilight Without Arduino for Non Addressable RGB Leds
If u Don't know What Ambilight is you must check youtube videos on Philips Ambilight
Now a days there's many way to do a replica or even a better looking reflections ..
the easiest way to do such a thing is with a cheap RGB led that isn't digital .. all the led will glow the same color ..
and without any sort of micro controllers or any embedded Systems such as Arduino, pic, and Raspberry PI
now you might think it won't be that good .. check my results ..
The main things you will need is :
.1 Breadboard, some wires, wire stripper and cutter, some soldering skills if your led is not already soldered
.2 12v RGB led with Common Anode [+], and 3 grounds for each color, thats 4 pins
.3 Your PC, with DVI-I[contains Analog pins], or the standered VGA
.4 A graphic card that supports multiscreen [atleast 2 screens, your main screen, and the virtual screen coloring the leds]
.5 NPN Transistors x3, i used bd543c because i have a very long led that demands much power.
.6 Optocoupler x3, also named Optoisolator, i used tlp521-4, it contains 4 photogates we will only use 3 of them.
.7 12v+ from your PC power supply [usually yellow wires]
.8 12v- [Black wires]
.9 5v+ also from the Power Supply [red wires]
Note: i didn't use any resistors because i didn't have any .. and im very bad at calculations .. :)
but it might heart something on your pc .. idk .. used this method for a while now and everything is still on :)
let's head to the dirty work ..
Step 1: The Dirty Work
first let's connect the optocoupler on the breadboard, check the datasheet for directions
connect the green or red or blue from your GPU port [DVI-I or VGA] to the Anode of the photogate.
the ground of the photogate must be connected to the ground of the same port ..
now apply 5v+ to the collector..
the emitter of the optocoupler gets connected to the base of the transistor ..
the collector of the 1st transistor get's 12V- [ground], and it's emitter goes to the led cathode color
apply 12v+ to your led common anode
apply the same rules for the rest of the colors ..
Check out the diagram diagram ..
Note: The Optocoupler must be placed in the middle of the breadboard .. because that separates the photogate pins from the collector and emitter ..
Step 2: Duplicate Screen
now we need to tell out os that there's another screen .. here's how to do it on windows 8.1:
press the windows button[keep holding it] + P [twice]
thats all :D
sometimes when you restart your pc it might get back to the original screen only .. do that again and you are on ..
Step 3: Results .. Yay :)
here ar my results using about 5m of cheap rgb leds i bought a while back .. for more please just ask in the comments :)
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    6 Comments
    hey i im a real noob and i love your tutorial, but im new with this stuff, so its a little bit complicated for me, i got a led strip like on your first picture...
    mine are conrtrolled over a little box with a IR controll and a extern power device....
    here are a picture:
    my question is
    how can i manage to connect the dvi from the gpu too it?where?
    can i just solder the red,blue or green and the black from dvi to the machting colors?
    or do i need a fotogene inbetween?
    if its not possible i will use these leds for your projects...
    but i would be cool because it has external powersupply and is already plug and play..
    thanks
    well, you can use the power supply to power up ur leds .., and u don't need the controller to do that .. but here's the thing .. are your leds common anode or common cathode ?
    thx im not sure ... i got the same stripes like in the main picture they have 4 pins.. how can i find out if they are anode or cathode?
    i made a better picture of the chip and the leds..
    i found this here: the guy used the board and the power of the original controller..
    i would like to combine your method with the the one from the link...
    would it be possible like this
    pc dvi signal ----> breadboard with Optocoupler and resistor --->board with power supply (old controller) ----> LED out
    12565608_754829627994969_9150660058071271152_n.jpg12631395_754831591328106_7917345401452800163_n.jpg
    sorry i couldnt post the link so here are some pictures of the other tutorial...
    Thanx :)
