This set of speakers is rugged, compact, easy to take on the go, and LOUD! The whole project will cost about $50.00 usd. and can be completed in an afternoon.
Step 1: Materials
Heres what you need:
1. One .50 caliber ammo box- http://www.joesarmynavyonline.com/servlet/Detail?no=5984
2. Two 4" speakers- http://www.amazon.com/Pyle-PL42BL-4-Inch-Two-Way-Speakers/dp/B000230LBI/ref=sr_1_2?ie=UTF8&qid=1291250695&sr=8-2
3. 2 sets of speaker wires- these will come with your speakers typically
4. 12 volt amplifier-http://www.dealextreme.com/details.dx/sku.34406
5. 3.5mm panel mount plug- http://www.radioshack.com/product/index.jsp?productId=2062450
6. 12 volt illuminated toggle switch- http:// http://www.radioshack.com/product/index.jsp?productId=206249312
7. Computer power supply- a broken one is ok for this, as you will just be using the plug and cord.
8. Egg carton foam- I had this piece of foam from some type of packaging.
9. 1 3/4" desk grommet- these can be found in the hardware store or office supply store.
10. 12 volt power supply- this is the kind of power supply that a laptop would use.
11. Two 4" computer fan grates.
12. 3.5mm male audio to rca audio
13. 3.5mm male to 3.5mm male audio cable
14. cheap little tripod from the dollar store
15. various hardware.
Step 2: Safety Gear
Step 3: Remove the Plug from the Power Supply
Next remove the screws that hold the actual plastic plug in place, and carefully pull the plug out and snip the three wires that are attached to it. set the rest of the power supply off to the side. you will not be needing this for any other parts.
Step 4: Mark the Ammo Box for Hole Placement
These are the holes that will be cut into the box
1. 2 speaker holes
2. Bass tube
3. Toggle switch
4. 4 holes for mounting the speakers
5. Hole for the panel mount audio jack
6. 4 holes for mounting the amp
7. hole for the power plug
8 2 holes for mounting power plug
The dimensions of these boxes vary slightly, so I am going to show you an easy way to do this that will not really require me to give exact dimensions as to where to cut.
I have detailed this part of the process in each following photo, to be as clear as possible.
Step 5: Cutting the holes: Speakers and bass tube
A drill bit 3/8" or larger in diameter
jigsaw with metal blade
round metal file
piece of scrap wood
The first thing is to put on your safety glasses so that you do not lose an eye. You need to cut a piece of scrap wood just long enough to fit in between the sides of the box (see photo). This will keep the metal from vibrating violently during the cutting process.
Step 6: Cutting Holes part 2: plug, audio jack, and screws
for this step you will need: Jigsaw with metal blade, drill with various sized bits, and a round file, I also used a deburring tool in this step.
Step 7: Cut up the tripod!
For this step you will need a phillips screwdriver and a pipe cutter.
Step 8: Mount the speakers
Step 9: Attach wires to plug
for this step you will need: wire strippers, phillips screwdriver, soldering gun, solder, flux, helping hands, and safety glasses.
Visit Our Store »
Go Pro Today »
Pod as well.
http://www.instructables.com/id/Curiously-Small-Audio-Switch/ http://www.amazon.com/gp/product/B006IJJH7O/ref=oh_details_o01_s00_i00 http://www.amazon.com/Hangar-12V-Battery-Charger-Combo/dp/B0006OBOFK/ref=sr_1_1?ie=UTF8&qid=1359437580&sr=8-1&keywords=hanger+12v+battery http://www.amazon.com/gp/product/B003XRK73W/ref=oh_details_o00_s00_i00 http://www.amazon.com/gp/product/B0007XFBE0/ref=oh_details_o00_s00_i01
You need to use the negative terminal on the battery as the ground point for all your wiring. There is not enough mass in the metal can to make an effective ground.
Kinter MA-700 amp (includes USB, RCA, and FM modes with a remote for which I mounted the receiver in between the speakers)
8x D cell bettery box internally
12v computer power supply
DPDT "ON-OFF-ON" switch
Speakers from an old stereo my dad had laying around
external speaker hookup from the same stereo which will connect to a pair of 50W bookshelf speakers I already have.
5A in line fuse and holder
3.5mm - 1/4" - RCA adapter string to plug in cell phone/mp3 player
all the necessary wiring was scavenged from the server or speakers.
All in all I am about $55 into it as I was able to get some free parts like the power supplies and such. I posted pics of the outside here, the inside will take a bit more to make it photo quality.
Thanks for the idea, I really needed something like this for camping trips and such and now I have it.
Speakers are motors. They move a diaphragm back and forth to produce sound. Sound is actually produced on both sides of diaphragm and they are the inverse of each other. That means that if the two waves were to meet at 0 degrees in time-space you wouldn't hear any sound at all since the two waves are canceling each other out. In all but dipole (which are very specialized and not at all applicable here) the sound created by the front of the speaker must be isolated from the sound coming from the rear of the speaker. This is why speakers come in boxes. A speaker may have multiple drivers in it but if all those drivers are sharing the same internal box volume, they're all working from the same signal. That means that if you have a speaker that has 4 woofer drivers in it, and there is no division in separating each of the woofer drivers, they're all working from the same source signal. All 4 drivers are working together to act as one larger driver.
In your box you've got two channels of sound (left and right) sharing one box volume. If you have two discrete channels they're going to, at some point since they're producing different sounds, be working against each other. This means you'll have significant dips in the sound produced because the speakers rearwave's are canceling each other out. What happens to the rearwave happens to the front wave as well. Here's what it looks like when you measure the spectrum. http://modulatedlight.org/optical_comms/comb_filtered_audio_spectrum_1a.gif That line should be relatively flat but it has severe dips. Granted that pic was created by AC hum interference but rearwave combing looks the same.
All driver's have what are called Thiele Small Parameters. They measure every aspect of how the driver reacts. These parameters are used by the engineer designing the speaker to model the output. If for instance you put a driver in a box that is too small, generally they lose a significant amount of low end. Speaker engineering is a balancing act of finding the right driver, putting it in the right sized box and creating the best crossover you can that meets your requirements for overall size, output, cost etc. If you slap any speaker you find into any box you have it will most likely make some sound but there is very little chance it will do it with any efficiency for both accurate reproduction or power output. There is a very good chance you can damage components as well.
You used an ammo can which is a very interesting speaker box. They're light, easily portable and fairly weather resistant. The problem is, the only damping you used was some foam. Most speaker boxes are built out of MDF or something very similar. MDF has a couple of key properties that make it useful for speakers. It's heavy which means it requires a lot of driver movement to make the speaker rock or move. It's very rigid. When a driver moves inward, if a speaker is sealed, the driver is compressing the air inside. One of the TSP's specifically measures a drivers ability to do this. If your box is not rigid when the driver moves inward the box can swell causing indirect resonance. Also when a driver moves inwards the rearwave moves away from the diaphragm and at some point will impact the rear wall of the box. If the box isn't rigid the rearwave will impart some of it's energy into the box which will resonate through the box to the outside. Again, it's bad when the rearwave gets out of the box. Also, just to be thorough, MDF is highly machinable which is makes fabrication with it very easy but that has no bearing on your project.
All speakers have a rated impedance. The TSP for it is Re. It's how many ohms of resistance a speaker provides. Amplifiers are also rated by how many ohms they can push a signal into. No matter what class amplifier you have (A,B,D,T) it will say somewhere in the documentation that it shouldn't be used with speakers rated less than X ohms. Generally home audio speakers are rated at 8 ohms and amplifiers are capable of driving a signal to 8 ohms without issue. On the other hand generally car audio speakers are rated at 4 ohms with matching car audio amplifier ratings. It appears that you're using a small home audio amplifier with a set of car audio coaxial drivers. It may not be the case but there's a very good chance you're powering those speakers with an amplifier that is not rated to do so. I'd imagine at some point you're going to have the amplifier fail. If you're lucky it will just stop working but it could do as much as cause a fire or shock someone touching any exposed metal.
You've also ported the box with a "bass tube". Ports are wonderful things but they must be calculated and the correct length, diameter and end correction chosen based on the TSP's of your drivers and the size of the enclosure. Doing anything else is just letting rearwaves out, which we already know isn't good.
I'd suggest you head over to the DIY section of www.AVSForum.com and take a peak around. Also, download WinISD pro which is a free tool that will help you model your drivers in different enclosures as well as garner an understanding of how the TSP's affect speaker performance.
Used a 50 cal ammo can which I applied a butyl sound deadening material to, some kicker 4" speakers, Lepai t-class amp and a 7ah 12vdc sla battery that is most commonly used in home alarm systems with quick connects for a battery tender for recharging. Audio is connected to a 3.5mm plug with my ipod. I also did some subtle customization to keep the military feel with the blacked out nut washer combo and the graphic i made and trimming the speaker grills in flat white.
The 7ah battery is a little overkill since this amp and speaker combo is very loud and efficient. Future mods in the next few weeks will include:
-port tube hidden under the latch
-lighter battery pack (prob a 3ah li-ion)
-speaker feet
-bluetooth connectivity
I have found lots of simple solutions on bluetooth receivers, some even run off of 12v so they could be wired to the battery... but the range problem still eludes me.
My idea was to make a tiny hole directly next to the speaker and have a tiny wire (antenna) go around the outside of the speaker to hide it inbetween the speaker body and the ammo box. That way you have an external antenna for the reviever thats partly hidden, maybe completely hidden by the speaker mounting body.
http://www.amazon.com/Britelink-Bluetooth-Audio-Receiver-Portable/dp/B0059M4G9K/ref=sr_1_3?ie=UTF8&qid=1346078657&sr=8-3&keywords=bluetooth+receiver
although I have yet to order it. Small, good battery life, rechargeable, great reviews. The only reason I am even attempting this is because I am porting my box and will be mounting the receiver directly above the port. Hoping this will allow adequate signal transmission but who knows. I will definitely post an update once it is all finished and let you know about the range.
Battery
Amp
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=320-304
The 7ah battery runs the amp easily over 48 hours without needing a charge... could be longer, i still haven't run it out. The battery weights about 7 pounds, making the box a nice and heavy manly man's stereo! haha.
Im no expert on electronics - was wondering if the batter wired straight to an amp like this needed any sort of regulation or protection - can you damage an amp by running the battery down to voltage below amp-spec?
Trying to find a battery that I can charge through an AC port on the can.
it does provide enough power and it has 12v and -12v and 0v, 5v and the list goes on.
How does it run 12v DC fans?
I hooked that holder up to a simple on off switch (to keep my 12v power supply seperate from my batteries. Just make sure you turn one power supply off before turning another on, the switch for the batteries will stop your other power supply from forcing 12 volts into the batteries (alkalines dont recharge and will leak).
As for wiring 12v electrical, its very simple, just google basic circuits to get an idea on how wiring works, and always use the KISS method! never overthink or overdesign beyond what you can do.
And once you got the basic idea on how to solder, use flux, etc just keep practicing on projects and it will turn out just fine at it.
