3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Amp Footswitch
Amp Footswitch
When I play guitar, I often switch between clean and overdrive, and I sometimes need to turn chorus on and off.  The problem here is that the buttons on my amp are about 1/4" squares, smack dab in between the knobs.  When I don't want to reach down to change settings, sometimes I can manage to use my toe to push the buttons, but often times I end up messing with the knobs accidentally.
While looking at my amp's manual, I saw that the label for the footswitch jack designated the functions of the TRS (Tip-Ring-Sleeve, or stereo) plug that would plug into the jack.  It was then that I had the idea that I should make a footswitch instead of buying one, just like any self-respecting geek would do.
By making my own footswitch, I was able to save a ton of money.  Most dual-button footswitches run somewhere around $50 or so, yet I was able to make mine for under $10.
Step 1Parts and Materials
Parts and Materials
The parts are pretty straightforward, but can be changed depending of what you already have.
Parts:
- 2 Push On/Push Off buttons*
- a 1/4" Male Stereo plug (I prefer solder-type)
- a cable of some sort with at least 3 conductors**
- an enclosure that will fit the switches
- you may need some hookup wire, but it's unlikely
*I have heard of amps that require a momentary switch instead of a push on/push off type.  You can check what you need by touching the wires for the switch together and seeing what happens.
**I used an old RCA audio cable, which has 2 conductors in each wire, then I soldered one from each together forming a common ground
Tools:
- Wire strippers
- Soldering iron & solder
- Drill with bits to match your buttons
9 comments
Dec 19, 2011. 6:29 PManonymouse197 says:
I have done this, but never thought to put it on instructables! :)
Aug 11, 2011. 1:28 PMlowkey30 says:
this is really funny for me because I found a commercially made switch setup at a yardsale and bought it for $1 so I could hack it to get the switches out of it for other projects!
Feb 17, 2011. 12:27 AMthe_burrito_master says:
why do you "tin" them first? does that avoid shorts or something?
Feb 24, 2011. 8:57 AMthe_burrito_master says:
oh, I guess that could help make a stronger joint, I like to just twist the wires together and drop a few drops of solder on them.
Dec 26, 2010. 6:39 PMthewizard42 says:
I have that same strat, but its a 2008 :D
Jun 21, 2010. 4:42 PMmattthegamer463 says:
Nice job. I built basically the exact same thing (from Fender's specifications) except I used DPDT footswitches designed for stompboxes, so they're super heavy duty units. Might be a good upgrade.
Jun 22, 2010. 4:35 AMmattthegamer463 says:
They were $4 each at a local store. Combined with a die-cast aluminum enclosure and the total cost was around $20. Picture: http://img.photobucket.com/albums/v321/mattthegamer463/Guitar%20Pedals/DSC01510Medium.jpg
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
124
Author:Radioactive_Legos
