loading
Step 8: Step 6: The Circuit
The sensible thing here would have been to use insulated electrical wire - the most common, if not ONLY, wire used for electronics, but that was not aesthetically suitable for what I wanted. So I took a piece which consisted of a fairly thick single strand instead of many thin strands, and stripped the insulation completely, leaving only bare wire. This looked much cooler, although it took a bit more planning to make sure no wires crossed.  I wired the circuit according to the diagram below - two sets of LEDs in series, each set in parallel, as well as a 2.2 ohm resistor which is not in the diagram . I used tiny spots of PVA glue to hold the wire down the the sensor bar.
Wow! This instructable is brilliant! I love the way that you don't do things the way that most people do them and how you do thing on the cheap, but beautifully! Well done, I think this is how ALL instructables should be done.
Wow, such glowing praise! Thank you very much, i'm glad to hear my work is appreciated
About This Instructable
12,360views
11favorites
License:
Bio: I study Aerospace Engineering at RMIT, in the hope that one day I will be able to bring about the return of intercontinental airship cruises ... More »
More by squiggy2:Autonomous Miniquad (software) Autonomous Miniquad (assembly) Wiring an Xbox Kinect for USB
Add instructable to:
