3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
An Algae Bioreactor from Recycled Water Bottles
Step 5Make Algae Media
Make Algae Media
We next make the medium to grow the algae. Although there are many possible mediums, a standard garden store fertilizer contains all the nitrogen and nutrients that the algae need.
7 comments
Feb 5, 2009. 8:51 AMGBlaze42 says:
What is the type of water you are using? is it distilled? normal tap water could be a problem.
Apr 1, 2009. 1:44 PMap66218 says:
distilled is always a safe bet with any experiment, but tap water that has sat out overnight can be used too, for that gives time for the chlorine in the water to dissipate.
Sep 3, 2009. 5:05 PMtiny.ian says:
This could be a problem... And there are other things to think about- such as minerals and metal content. The biggest problem is Chloramine, which does not evaporate. Some areas don't use chlorine. In Los Angeles, for example, chlorine and chloramine are used. Also, there's the possibility of copper (which kills algae REALLY well), lead, various salts, and other substances in tap water that are better removed by filtration. To remove both chlorine and chloramine, as well as reducing the other stuff, you can use a cheap carbon filter tube (found in many hardware stores for filtering water). Pass the water through the filter and you will be left with clean, chlorine (chloramine) free water thats good enough to put pretty fish in!
Sep 3, 2009. 7:05 PMGBlaze42 says:
Thanks for the tips!
Sep 3, 2009. 7:00 PMGBlaze42 says:
(removed by author or community request)
Apr 26, 2009. 8:43 AMmlzupan says:
In a closed loop system there is no way for it to get co2 from the atmosphere. If it is an open system it will get co2 from the air - and probably enough to grow algae - algae in a pond has no problem growing. However, if you want to accelerate the growth of algae - adding additional co2 will increase the speed with which it will grow and increase your harvest cycles.
Feb 6, 2009. 8:42 AMhalera says:
do you need to add CO2, won't the algae grow anyway getting the naturally occurring CO2 from the atmosphere?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:mfischer
Michael Fischer
