An Arduino Thermometer With Digital Display
Published
Introduction: An Arduino Thermometer With Digital Display
About: Technologist, Electronic Engineer, sometime Coderdojo mentor.
This is a project for Arduino to make a Thermometer with Digital Display, aimed at beginners.
Arduino measures the voltage on a TMP36 Temperature sensor, converts the Voltage to Degrees Celcius and Displays the value on an LOL shield display.
Objectives:
* Learn how to use the TMP36
* Learn how to perform numeric and string conversions in Arduino-C  (sketch)
* Learn how to display numbers on the LOL shield
Step 1: What You Need
You will need:
* Arduino UNO
* LOL shield   (http://jimmieprodgers.com/kits/lolshield/)
* TMP36 Temperature Sensing IC
* Breadboard for wiring up e.g. (http://www.oomlout.co.uk/prototyping-bundle-for-arduino-ardp-p-186.html)
* Some Wires
Step 2: Wire It Up
Wire the TMP36 as follows:
+5V
GND
SIG => A0
Note: The LOL shield does not come with Headers (as shown in the picture), attached to the topside.
I bought some here: http://www.amazon.co.uk/gp/product/B004RASBVY/ref=oh_details_o06_s00_i00
Step 3: Install the LOL Shield Libraries
Install the Arduino libraries for the LOL shield if you don't have them already.
You can get the link to them from this page:
Step 4: Let's Start by Reading the Temperature
The code for temperature reading is shown in the Next Step. Step 7 shows the full code for the project. For now let's see the main ideas that make the code work.
We'll start by reading the temperature from the TMP36 and sending the value to the Serial Monitor (Tools -> Serial Monitor on the Arduino IDE).
The TMP36 outputs a voltage on the SIG pin proportional to temperature.
Zero degrees Celcius = 500mV   (0.5)
Each degree above that = 10mV   (1/100)
Here's a code segment:
float temperature = getVoltage(A0);                        // Get the voltage reading
temperature = (temperature - .5) * 100;                  // Convert to Temperature (degrees C)
Step 5: Here's the Full Code to Write Temperature to the Serial Monitor
* Displays Temperature from TMP36 on the Serial Monitor
* Adapted from (and for more details on this circuit): http://tinyurl.com/c89tvd
//TMP36 Pin Variables
int temperaturePin = 0;
//the analog pin the TMP36's Vout (sense) pin is connected to
                        //the resolution is 10 mV / degree centigrade
                        //(500 mV offset) i.e. 0 degrees = 500mV
* setup() - this function runs once when you turn your Arduino on
* We initialize the serial connection with the computer
void setup()
  Serial.begin(9600);
//Start the serial connection with the computer
void loop()
// run over and over again
  float temperature = getVoltage(temperaturePin);
// Get the Voltage reading from the tem
perature sensor
  temperature = (temperature - .5) * 100;                 // Convert from 10 mv per degree with 500mV offset
  Serial.println(temperature);                     // Print the result
  delay(1000);                                             // Wait a second
* getVoltage() - returns the voltage on the analog input defined by
* pin
float getVoltage(int pin){
  return (analogRead(pin) * 5.0/1024);
//converting from a 0 to 1023 digital range
                                                            // to 0 to 5 volts (each 1 reading equals ~ 5 mV)
Step 6: How to Use the Display
Once you've included the library:
#include "Myfont.h"
You need to initialise the display in the Setup section:
void setup()
    LedSign::Init();
and Draw the relevant digit in the Loop section:
Myfont::Draw(x_pos, 'a');                 // Send a character to the LOL shield
where x_pos is an int holding the x position where you want the number to be display (zero is the left hand edge).
In the final code you will need to convert the temperature reading (a float). To a char so that it can be displayed on the LOL shield using the Draw command.
To do this we use ltoa in C as follows:
temperature = (temperature - .5) * 100;        // Convert to Temperature (a float)
ltoa(long(temperature), buffer, 10);            // buffer is a 12 location char i.e.
char buffer[12];
for (int i=0; i<2; i++) {                                   // Iterate through the buffer for 2 characters
   Myfont::Draw(1 + i*6,buffer[i]);                 // Send each character to the LOL shield
Notice the x position is:
1 + i*6
this means the first character (i=0) is at x position 1
and their spaced 6 apart (e.g. i=1, x position = 1 + 6 = 7
Also notice the buffer for ltoa() is 12 long. This is a detail related to the length of long in C and allocation of sufficient memory.
Step 7: Here's the Full Code
* Displays Temperature from TMP36 numerically on an LOL shield
#include "Charliplexing.h"
#include "Myfont.h"
int temperaturePin = 0; //the analog pin the TMP36's Vout (sense) pin is connected to
char buffer[12];
void setup()
    LedSign::Init();
    Serial.begin(9600);
void loop()
// Get the Voltage reading from the temperature sensor
  Serial.println(temperature);                                  // printing the result for debug
    Myfont::Draw(1+i*6,buffer[i]);                         // Sending each character to the LOL shield
  delay(1000);
// wait a second
  LedSign::Clear();                                              // Clear the display
* pin
Step 8: Enjoy
Why not make it better by
: making the digits scroll e.g. Myfont::Banner();
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    Nice project :)
    Just curious, are there any resistors in the lol shield for LED-s?
