What is a Question?
Questions are a super-easy way to get answers from the Instructables community. Learn how to build, do, or make anything! You just ask a question and the community will provide answers. You choose the best answer!
Submit a Forum Topic! The forums are the place to ask questions, share a cool project from another site, find collaborators for your latest project, or discuss anything of interest to the Instructables community.
Do you have a lot of images to upload?
If you prefer to upload your images before you submit, then this is for you.
Remember to tag them so they will be easier for you to find when you are viewing your library.
You can also upload images when you are creating your posts.
Did you find a bug or have a suggestion for us?
We appreciate all the help our users give us in tracking down bugs and making the site better for everyone.
PhotosPhotos
I have replaced several of these pieces, but they continuted to rot out. Hence the corner brace of concrete. Replacing the piece is simply a matter of unbolting the old piece, cleaning up the area so that the new pieces can be put into place, and installing the new corner braces.
lol, yea, I was trying to figure out why you went to all the trouble to make the concrete corners. Why have corners at all, just nail the wood together with galvanized nails and lay some plastic in there and be done with it. But the concrete is super cool, you could use PVC. Just slit a 4" or so pvc pipe down the center heat it up and lay it on a flat surface. You'd have a flat plastic piece that will never rot and probably cheaper then a bunch of concrete.
The problem is that PVC releases toxic chemicals such as dioxin when heated and even after it's cooled and hardened again it is much more prone to leaching the chemicals into the soil and your edibles. At least concrete mostly just produces CO2 when made-and in many cases it somewhat safely binds/incorporates "fly ash" (a by-product of burning coal) that would otherwise be a pollutant.
Side note: cement production *is* one of the largest contributors to the rise of atmospheric CO2 but when used carefully in small amounts and for durable uses like in this project, it can make up for it.
It looks like you're pretty set on where you would like these things and, if that is this case, why not just make the entire thing out of concrete? Build a 6" tall form, use either fibers or steel reinforcement... maybe 2-3 inches wide... you'll never have to replace a board again!
