iImage Information
The cutoff wheel is one of my favorite tools for use on a Dremel. But, the little discs do not last long when cutting on a piece of sheet metal and frequently need to be changed. That means I need to have a screwdriver at hand to remove the small screw that holds the disc in place, and to tighten the new disc onto the mandrel. This Instructable will show a simple modification that should be standard on every Dremel. The only thing needed to make this modification is a grinding stone. One attached to a Dremel will do the job.
Step 1Screwdriver options
iImage Information
I usually use a very small screwdriver, but I also discovered the middle screwdriver bit on my Leatherman PST will also do the job in a case of necessity.
http://www.dremel.com/en-us/Tools/Pages/ToolDetail.aspx?pid=EZ406
The link above takes you to a reinforced cutting wheel that swaps out really easily. No need to bother with the wrench or screws.
Its much easier, and discs last longer too.
Anyhoo, this is a good Instructable if you don't have the wrench with the screwdriver already integrated.
Anyway it's a nice idea sharpening a side... mmmh dangerous ideas comming hehe
This is a great idea for all the older dremel tools out there. Mine did not come with a combo tool either.
Though I suppose Bosch's name brand tools are their best line. I just picked up their 1608 Colt trim router. It's quite the 800 Watt Dremel :)
