An Easy and Permanent Fix for Older Car Door Seals.
248,952
259
20
Published
Introduction: An Easy and Permanent Fix for Older Car Door Seals.
About: The name comes from the First Star Trek movie, that pretty much says it all.
     In many older cars the rubber door seals don't seal the way they should. Often the seals have pulled away from the door frame and leave gaps between the frame and the seal, almost always in the corners. This lets in cold or hot air, sometimes water and almost always excess noise. So many older cars have a noisier, drafty  ride because the seals are not tight.
     Many people think that the reason for the seals not staying in the frame is that they have come unglued. They will often try to glue them back in place but the seals will not stay there. That is because they are not glued in to begin with.  The door seals are held in place by simple pressure. When the rubber seals get older the rubber shrinks, the older the seal the greater the shrinking. As it shrinks it pulls away from the door frame almost always at one of the corners. No matter how much glue you use you will not get the seal to stay in place because the seal is now to small to fit the opening. But there is a simple and very cheap fix for the problem that is permanent. You have to make the door seal bigger.  Its a lot easier to do than you might think.
Step 1: Find the Seam Where the Seal Is Joined
The first thing to do to fix the problem is find the seam were the seal is joined. This will almost always be located under the plastic sill that protects the bottom of the door frame. Pry the sill up and off to get access. If yours is screwed down then remove the screws. Most have plastic connectors that go into holes in the floor and they are just pressed in place. They should pull up easily.
Once you have that out of the way you should see the place where the deal is joined. It will probable look like it has been glued or fused together.  This is the easiest place to cut the seal. Most of these seals have a metal component running through them to make them rigid and cutting it can be hard. The seam has no metal so you can slice it through with a razor knife or a pair of heavy duty scissors.
After you have cut it you can push the seal back into the door frame corners where it is supposed to be. Sometimes it easiest to pull a section off and then start at the top pushing it back tight working your way back to where you cut it. Now you will be able to see how much your seal has shrunk.
Step 2: Add an Extra Piece
Find an extra chunk of door seal, a foot or so will do. You can get this from a junk yard or from another car even. You can also buy seals but they are expensive. I took a piece out of a a minivan that is used as a parts car. The best one to get is one that matches your car. If you can't get that then try and get one that is a close match.  Door seals can be difficult to cut because of the metal pieces in it.  I used a pair of tin snips to cut mine. Really heavy duty scissors might work also. A knife will only cut the rubber.  A hack saw will work but its a little more effort.
After you get your seal material figure out how much to cut to fill the gap. First make sure the seal is pushed completely into the door frame.  Next mark on your chunk of seal where to cut. Make it BIGGER than the gap by about  a half inch. This way when you put it in place it will push against the rest of the door seal and help to force it to stay in place.
Push the piece you cut into the gap and hammer it down with your hand. You should not have to do it very hard.  It goes in pretty easily. You don't need to use any type of glue since the pressure will and the sill cover will keep it in place.
Step 3: All Sealed Up, Now Do the Rest of the Doors.
After you get the filler piece in place put the plastic sill cover back on.  Again just a hit with your palm should be enough to snap it in place.
And that is it. Your door seal is now tight and will stay in place for years until it shrinks some more. If, when, that happens just put in a bigger filler piece.
Now how come the car makers don't make seals so you can add spacers to them?  It would be an easy source of income for them to sell DIY spacers that people could just pop into place and seal up their doors. Oh, wait, that would mean they would be keeping the cars until they were older and not buying new ones. Never mind.
Do this same procedure for all the doors of your car. If one has shrunk then they all have shrunk.
Enjoy the quieter ride.
Cars & Motorcycles Contest
Second Prize in the
Fix It Contest
Finalist in the
Fix It Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    20 Comments
    I saw this and thought YAY just the thing! But I looked at my Ford 500 gasket which has come loose, and it is one continuous piece, no joint and no "threshold" on the bottom. Do you suppose silicone adhesive would hold it in place?
    The main purpose of the threshold, as far as I know is to keep the seal from getting torn up from being constantly stepped on. It is likely that if you glue the seal in place it will last for a little while and then pull loose again. I would cut it at a spot where it is easy to expand it and then reseat it and see how much it has shrunk. You can use rubber cement or the stuff for repairing tires to glue in a small expansion piece. You will end up with a patched seal but it should fit tight again.
    Question...mine is loos from the top, not the corners. It doesn't sound like this will work for me, what do you think? Any suggestions?
    This will work for you. After removing the plastic piece at the bottom, I found that my rubber seal was not a continuous piece, and that the plastic just holds the ends tightly in place. With the plastic remove, I could start at the top that kept falling down and just work the rubber seal up and around the entire door. Replacing the plastic bottom now holds the ends in place with the seal seated tight all the way around the door. Give it a try.
    For 5 years I have just been pushing the seal back up when It started to pull away. I read your article, and today I removed the plastic bottom part and found that it actually holds the ends of the seal tightly in place. With the plastic off, I started at the loosest spot and pulled the rubber seal up and around the entire opening until it seated completely. I replaced the plastic, and it now holds the rubber tight all the way around. Presto! Thank you so much!
    Is it OK that there is now a gap in the rubber at the bottom?
    If it is a big gap I would try and fill it. Most likely it will not bother anything since it is covered by the plastic sill but it might let a little dust and noise it. Much less than if its pulled away from the frame. So given the choice, in my opinion, its better to have the seal in the correct place with a gap at the bottom than no gap but the seal pulled away from the frame.
    I really wish I had known this years ago.
    Wow! Thanks so much for putting this together!
    SO simple thank you :) seals usually start at 150 - 350 so this is perfect and ill do my Ford Territory this weekend :)
    Looking forward to warm weather so I can try this. I think it's a brilliant solution! Thanks for posting.
    great article, thank you.
    This will perfect for my '84 rx-7. Thanks so much!
    you might want to try using a gasket maker like Permatex ultra black so that you can make it look like the seam was joined from the factory
    Another way to improve weak door seals (the hollow type) is to feed windscreen washer tubing through the center all around the seal, it works on some modern cars too
    Nice one, this is now on my to do list.
    good job. nice and clear instructions.
    Good to know. Thanks for the tip!
