3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
An easy to build Stirling Engine fan
The idea behind this instructable was to make an easy to build Stirling engine, that can be built by almost anyone. It runs on only one candle, which is a bonus, although I can't honestly say it moves much air! This engine is easier to build than my last one, and should be more reliable.
Step 1Tools and materials
Tools and materials
I'd like to be able to magic a Stirling engine out of thin air, unfortunately, I can't. So you'll need some materials and tools, they are listed below. If you spot an omission, please post a comment and let me know.
Materials :
  •  6 - 8  Coke cans
  • A small scrap of wood about 6cm x 2cm x 2cm
  • A balloon
  • A tuna paste lid
  • A spoke from a bicycle wheel
  • 1.2mm steel wire
  • Epoxy
  • Super glue
  • A 2p coin for counterbalancing
  • Sellotape
  • 2 x Electrical screw blocks
  • Piece of thick cardboard about 15cm square
  • BBQ Skewers
  • Paper
  • 1.59mm (1/16") brass rod
  • 2.38mm (3/32") brass tube
  • Another scrap block of wood for the jig at least 75 x 75 x 20mm
  • Plastic bottle lid
  • Steel wire wool
  • A drawing pin
Tools :
  • Scissors
  • Drill with 2mm and 6 - 8mm HSS drill bit
  • Tin Snips (you can get away without these, but they make life easier)
  • Pliers (two pairs of pliers comes in very handy)
  • Needle nose pliers
  • Can opener
  • Stanley knife
  • Half round file
  • Saw to cut wood, if necessary
112 comments
1-40 of 112next »
Aug 22, 2010. 2:37 PMtyler1440 says:
Rubber bands work really well to hold the wood to the can while you epoxy it.
May 9, 2012. 12:24 AMpotta says:
ssss
Dec 16, 2011. 11:59 AMelectrowizard says:
ok,thanks.
Dec 16, 2011. 11:50 AMelectrowizard says:
ok,mow why do you havew a solid wire here? in your other instructable,you said you didn't need a stiff wire. O_o???????
Aug 14, 2011. 6:55 AMMarstaronz says:
I am currently pursuing mechanical engineering pls suggets me some project idea which is also a contribution to the society............................
Aug 7, 2011. 10:12 AMhayme says:
And are you sure the displacer should be 35mm tall? i know how big is 35mm. And i only get to have a piece of material RARELY because im not in god's land a.k.a USA. i don't want to cut things until im sure of it.
Aug 7, 2011. 10:04 AMhayme says:
does it affect the machine if the rod is heavy? e.g.: slow spinning, INEVITABLY NOT WORKING?! etc. help me.
Jun 24, 2011. 4:02 AMhayme says:
Can i use glue stick?
Jun 7, 2011. 2:51 AMakarsh shukla says:
please send me pdf file,i'm not a pro member.please
May 23, 2011. 7:37 AMibtassam says:
Hi scraptopower, I wonder if you still remember the discussion we had on this thread.
Well I wasn't successful in making the engine run but I did some software magic and ran it. Here's the video I made of it. Hope you like it. http://www.youtube.com/watch?v=HePOO2Y38Bg
May 22, 2011. 9:11 AMmad doctor says:
could the balloon be replaced by a rubber band?
Apr 4, 2011. 1:07 PMaashilrv says:
Someone plz help me
when i rise my displacer it the diaghram moves but it doest have enough stength to push against the cranks .plz help me
Mar 21, 2011. 6:00 AMaashilrv says:
can i use a straw instead of wood?
Mar 21, 2011. 5:53 AMaashilrv says:
i ve been trying to build a stirling engine for 2 weeks.So far ive had 4 failures but i am not gonna give up...........
Mar 18, 2011. 6:40 PMZippo1234 says:
what can you use for the displacer other than steel wool?
Feb 27, 2011. 2:23 PMalexsparrow says:
you spelled center wrong
Feb 27, 2011. 6:02 PMalexsparrow says:
sorry dude my mistake
Mar 9, 2011. 10:51 AMPowerToaster says:
things are done a bit differently in the UK, Alex.
Mar 7, 2011. 2:08 PMRyan McDougall says:
To scraptopower:
Could you please send me a pdf file of the whole instructable
Im not a pro member so i cant veiw it.
i want to print it out,
Thanks
Mar 7, 2011. 10:33 PMRyan McDougall says:
Thankyou so much scraptopower
Im 11ys old and i love your instructables( nice layout, wording and pits)
PS: insted of peice of wood as a tube(it conects to the ballon) Can i use a pvc
90 degree elbo.
thanks.
Mar 8, 2011. 11:16 PMRyan McDougall says:
just a nother qestion is this diagam move to much
Mar 8, 2011. 10:09 PMRyan McDougall says:
Sweet,
Thanks, im planing on makeing this. this weekend
Feb 27, 2011. 2:22 PMalexsparrow says:
hey scraptoppower i suggest using some wood to hold the thing still so it won't move
Feb 19, 2011. 9:50 AMibtassam says:
I have a question.
Is this version, alpha beta or gamma stirling?
My knowledge says that
Alpha has two cylinders for 2 pistons, beta has whole assembly in one cylinder.
Can you please explain me in your terms, the difference between these?
Feb 16, 2011. 8:55 AMibtassam says:
Hi Scraptopower,
First of all, I'll like to appreciate the great work you've done by making an instructable of your work. I'm sure it must've been hard work.
Secondly, I was making almost exact replica of your stirling model for a mini-project and followed your steps to about 95%(I didn't use the wood thing in front of air hole, instead i used an elbow). But after working on it for 2 weeks and finally completing it 2 days ago, I've not been able to run it. :(
For past 2 days, I've been trying to correct it, somehow, trying to make it work but it's not working. :( The whole thing's pretty air tight. The crankshaft is at right angle. The bushing is in place. The displacer falls on it's own weight. Everything is right where it's supposed to be(apart from flywheel, firebox which I didn't install yet because I first wanted to make it work) still it's not working. And I'm reaching the fine line between interesting work and frustrating work. Is there anything you can suggest that may help me in this matter.
Feb 16, 2011. 10:02 AMibtassam says:
Well, to be honest, I don't think the engine isn't working because of no flywheel as It should at the very least give me the sensation of moving by itself in going from TDC to BDC but it's not doing that either. I don't really know what I should use to make the flywheel? Will a tea cup coaster work.
And I've wrote down the things I'll change in this engine tomorrow. This list includes changing the diaphragm(which I made from rubber gloves). Although they work pretty well when I rotate the crankshaft manually, but I'm starting to think it's probably less flexible. Secondly, my crankarms are straight so I can't really adjust them(maybe as a last resort when my engine is working but giving less rpm) but they're not the problem I think as I worked really hard to get them right. The crankarm on diaphragm side compresses the diaphragm by approximately 5-10 mm.
Also, Although I've epoxied everything but there are two things I haven't superglued/epoxied.
(i) The diaphragm, around which I rolled thread really tightly and 3 seperate times.
(ii) The crankshaft/displacer cans are also not epoxied yet but have been taped really tightly. ( I didn't epoxy them yet as I thought I may have to open the displacer can again but I think I should epoxy it now as I have already adjusted the height of wire wool on displacer so that crankshaft can rotate freely).
I'll install the flywheel and change the diaphragm but that's just about all i can think of right now. :(
Feb 17, 2011. 3:40 AMibtassam says:
I tried to move the crank arm up and down and it only moved the crankshaft by about 90*. And my guess of 5 to 10 mm is wrong as it only compresses about 5 mm at most when I compress it myself so basically I feel the main problem is the large amount of force needed to overcome the flexibility of this diaphragm as compared to what it would have been for the balloon(but I have bought a couple of balloons) and am going to try them out. (Should I place the balloon in highly stretched state on the cap or should it stretched just enough so that there are no wrinkles or should it be really loose) Is it ok if I seal it by rolling the thread around it?
My heat source is a stove at the moment but I keep the can at a safe distance so that it doesn't get burned plus I also poured some water near the bushing area.
Feb 17, 2011. 11:43 PMibtassam says:
Hey scraptopower,
I have now tested stirling with the new changes but it still doesn't run. However, I did get a slight sensation of moving by itself when the displacer starts to fall. Although it would fall anyway but there was a really small increase in speed while falling , I feel.
I have followed everything written but still it's not working and now I'm all out of ideas what to do. Is there any way I can make it run for sure??
I've attached a picture just in case you spot anything.
1-40 of 112next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
312
Author:scraptopower(Scrap to power)
Always a brew in hand, I like to make stuff.
