Please rate me, it just takes a click. Thanks!
Weeks later of googling, and reading forum after forum I came up with a circuit that I was happy with. Realistically this would have been easier using a micro controller but I was rich on time "or so i thought" and low on cash. Total cost of this panel including the wood frame has been around 35$ Now of course I did have to scrounge, look for freebies and of course use eBay. I live in a quite remote section of Northern British Columbia, so sadly there was no quick run to an electronics supply store. This table was to go to my best friend for a Christmas present but sadly, I ran out of time. He got an radiant ceiling mounted heater for his garage instead. So the LED pods I built, sat in bin being bounced around for a year and a half. They looked so sad and neglected, all they need was a home, some 12V juice and a little love, See what they needed for a happy home on the
next pages
ADDITION:
- I forgot to mention, this table was built as a panel. That is why the power is on the side. The panel can easily be moved about, it can be placed on my coffee table, kitchen table or even the wall as interactive wall art. I believe this is important as my family likes to be able to mix up our furniture arrangement and may not always want such as large piece to be hard to move around . In pictures and videos the table is sitting on top of my living room coffee table. It would be simple to add permanent legs or even cheat a little and pick up a cheap used table and buck the legs to the desired height
- I have added a new circuit diagram in step 4, feel free to comment, give advice and poke holes - its how we all learn, and I have a lot of learning to do!
- Added the write-up on building the frame, guess I didn't save it properly when I wrote it the first time. Live and learn...
- See step 11 for some pictures with a paper diffuser added! This optional but it does soften the look. This is fire resistant paper, the kind used for lamp shades, I thought this prudent as the power source could potentially spark or heat up
- Wife's friend they sell similar tables to parents with children with sensory seeking Autism.
Before building this table, remember your are using dangerous power tools, exposing yourself to potentially lethal doses of electricity, cutting yourself with broken glass, burning yourself with solder, dealing with nasty paint fumes and in general annoying the crap out of those you live with, and danger unto its own! So be warned!
Remove these ads by
Signing UpStep 1: Supplies, supplies, supplies
Supplies needed
Panel
*Most of the panel supplies can be skipped if you all ready have a ready built glass table with enough space below to contain the electronics.
- One 48"x30" sheet of tempered or laminated safety glass
- Two eight foot 2"x4"s
- Four eight foot 1"x4"s or 2 eight foot 1"x1"s if you can find them cheap
- Two 1/4" thick pieces of wood paneling/plywood one being 48"x30", other one 49"x31"
- Wood screws, 3/4", 1-1/2", 3-1/2
- Gorilla Glue
- Stain & corresponding sealant or paint
Electronics
- 240 Leds
- 300 12v 470 ohm resistors
- 60 22k resistors
- 60 3 leg photo transistors
- 120 transistors (2N 3904 -J05)
- Spool of bailing wire
- Small spool of thin non stranded copper wire
- Ethernet cable or equivalent
- Simple SPST switch
- 12v DC bulb and holder
- Converted computer power supply
- Electronics grade solder
- Hot glue
- Electrical tape or shrink tubing
- Thins sheets of semi flexible clear plastic, I used the replaceable plastic face inserts from a face guard I no longer had the base for, "waste not want not"
- black silicone tubing, similar to kind used for fishing gear, or sling-shots
- Table saw
- Circular saw
- Drill
- Router
- Hand held power planer
- Soldering iron
- Other tools used for the wood frame are up to you, its just matter or preference or budget.
Visit Our Store »
Go Pro Today »
Yours Christopher
so i am working on a bike project that i want to replace the 3 old head lights with 3 leds and i want them to be hooked up to 3 toggle switches
the nly problem is that i am a newB at lighting and circuits so if any one could give me any ideas i would greatly appreciate it.
thanks.
I have conected everything but it dosent work jus leds lights and nothing more and i used IR photo tranzistor. Plz help me . my email riciuksss@gmail.com
Just a thought though, have you brought the completed powered circuit into a room of complete darkness? It might just be the sensitivity level of the photo diode/transistor you are using. when i first did the circuit, it wouldn't work. In frustration I left it where i was working during the day, in my back sun room. Later that night, i went to retrieve something from the sun room and low and behold the leds were one, as soon as I flicked on the lights it went out, flicked them off again and it began to glow. Keep in mind, the only lights that will keep the leds in the off position is sunlight, halogen or conventional. Fluorescent lights will have no effect. The photo transistor used in the instructable had a different sensitivity level and made all the difference.
diferent from schematic that I whas bulding I will try soon and I will
tell you about it.
I used http://www.evita.lt/show_doc.php?id=10920
an 3 kindes of photo tranzistors http://www.evita.lt/?pid=catalogue&action=search&keyword=fototranzistorius&submit=Ie%C5%A1koti
And the same ...
Just a question, how many milliampere is used?
Thanks
Maybe you can read information about your power source?
Otherwise it's ok, I'll test.
Thanks for your fast answer.
thank you
As a thought, if slow turn-on was required (to make it look more analogue ;-)), a capacitor could be added across the first 2N3904's Collector and Emitter.
The 22k would charge it when the photo sensor detects darkness.
Just a thought. Haven't tried it yet, but should work okay.
Great work and great ible!
I cant hear it as well, Sound is very bad.
No Interest in reading further.
=8-)
really cool instructable!
i've got one lil question.
i'm not the best at creating circuits and stuff but the building part goes pretty well.
does the pod go out when you "dim the light" or does it really stay lit like forever?
i'm planning on making one of those tables myself and i thought it'll be cool if there where a few who dimmed when light dims, so that's why i'm asking.
hope to hear from you
btw, i reached step 7 reading until i really read your name and i kinda laughed out loud:P but it's a cool name
1) This has got to be the SIMPLEST circuit I have seen with fading LEDs in a table! I hope I can make something like this in the near future - it's so awesome!
2) I'm just thinking this now, but what could help a little with the fade in and fade out of the LEDs brightness is dedicate a ring that isolates the photo-transistor from any light coming in sideways and is flush with the underside of the glass or plastic top (like the waterproof IR light security cameras with the foam around the lens so the IR doesn't affect the video at night).
3) What would be cool if you could make an actual light piano that actually plays notes when one of the photo transistors is covered and turns on the LEDs - that would be cool and a great entertainer!
In all, really great intructable!
I just soldered the components on a board as shown on the circuit diagram and supplied it with 12v but no LED are now lighting up at all
Seems a bit wasteful of power, and even if you don't care about that, its a less elegant solution, which is what we analog people care about anyway =P
Very nice by the way .
set of 4 diodes can be made with one resistor =)
and then i dont get it why did u use another transistor when you could have connected collector of photo transistor onto base of inverting transistor? :P
transistor what turns on transistor is like having switch for switch for light =)
if all led's are same, and in paralell, they have same voltage drop, and total current is euqal to all currents together. so taking one resistor 4x value of one single led will work just fine =)
hope i helped =)
eh i tought it would work with IR leds... =)
one question... how much hours of work did you spend on that table?
remote controler sends impulses to tv so it is supposed to flicker =)
light sensitivity can be modified by changing resistor value on photo transistor and resistors on switch transistor, but it would be perfect if you used capacitive or inductive sensor. inductive sensor has short range, but you dont even need some wide sensitivity and they are quite easy to build, especially if you need their sensitivity to be on 1cm range
Your work deserves to be praised!
http://www.youtube.com/watch?v=brvqgpBtCr8&feature=channel
