It's all done through the magic of a free circuit simulator called LTSpice. Now I know you're probably saying "Gee willikers, Tyler, I don't know anything about running a circuit simulator- that sounds HARD!". Don't worry, Bunky! It's easy and I'll give you a few templates to start with and modify to make whatever weird noises you want.
Not sure it's worth the effort? Here's a link to a ready to play sound file (it is made from "composition_1.asc" in step 7 of this 'ible) that you can try out. I converted it from .wav to mp3 to reduce the download time. http://www.rehorst.com/mrehorst/instructables/composition_1.mp3
There's some low bass in it the sound so listen with headphones or good speakers.
If you like what you see, vote for me!
Note: I have attached schematic files for LTSpice that you can run on your computer, but for some reason when you try to download them the names and extensions get changed. The contents of the files look OK, so after downloading the files just change the names and extensions and they should work. The correct names and extensions are shown on the icons you click to download.
Remove these ads by
Signing UpStep 1First things first
Download a copy of LTSpice for Windows (ugh!) here:
http://www.linear.com/designtools/software/ltspice.jsp
Install it.
What is LTSpice? It is a time-domain circuit simulator that every electronics hobbyist ought to know how to use. I'm not going to provide a detailed tutorial on how it works here, but I will explain a few things you'll need to know as we go along.
One word of warning- it is easily possible to produce frequencies that are too low or too high to hear. If you do that and drive your expensive speakers with a high powered amp you may just blow your speakers/amp to bits. ALWAYS look at the waveforms before you play them back and be careful to limit the volume when you play back a file for the first time just to be safe. It is always a good idea to play the files via cheap headphones at low volume before trying speakers.
Musicians probably wouldn't bother, but it can be used to make a high resolution test CD or can be used as a signal source for electronic testing. It can also be used to test the response of a circuit you want to simulate, say a crossover for an audio system, etc.
ive a old casio im going to build something with im still in the research of the what all to atempt with it , i did manage to get all its components out 150 screws latter i put it back up on the thinking of what to do with it shelf lol
My first post for 1 year that i read this fantastic website,
but i must say that your project is just
awesome ! and for both educational and experimental purpose !
Thank's a lot and BRAVO !
Alexis (from Paris, France)
