3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Analog Text Encryption-Compression Technique
Using only a rubber band and permanent marker or ink pen, it is possible to encrypt and decrypt a text message using only the muscle power in your fingers.
Step 1Let's stretch before begining
Let\
Take a rubber band that is wide enough to write on, and stretch it tightly around a flat surface. The surface could be a book, or in this case, a roll of duct tape. The tighter the stretch, the better the results.
21 comments
May 18, 2011. 9:15 AMxc1024 says:
It's not encryption, it's obfuscation. Encryption results in output that can be only turned back to the original message if you have the encryption key. If it doesn't require key to read it, it's called encoding. If it is designed to obfuscate the message (make it harder to read) then it's obfuscation.
What we have in this case is definitely obfuscation.
Jul 31, 2010. 5:44 AMluvit says:
i'm illiterate. this helps me with my illiteracy.
May 26, 2010. 2:19 PMChowmix12 says:
Very Clever! 5/5*
Dec 27, 2007. 10:40 AMXeropoint says:
This is really cool... Suprisingly, i never thought about doing this. lol
Feb 22, 2007. 5:22 PMBad Donut says:
Reminds me of when there is written text on a ballon that it extremely small before you blow it up. Fun!
Nov 14, 2006. 4:29 PMfungus amungus says:
I remember doing this as a kid. I think I saw it on The Littles.
Nov 21, 2006. 3:17 PMcarbon says:
The littles? That show with those tiny, mouse/people things? Wow, I thought I was the only one.
Nov 21, 2006. 11:33 PMfungus amungus says:
Yup. I used to love that show.
Jan 21, 2007. 3:54 AMfinfan7 says:
its actually still on here. so bizarre to watch after you haven't slept.
Nov 15, 2006. 8:25 PMcanida says:
This is how we used to write our names on swimming goggle straps when I was a kid- it looks neat even if the letters are only slightly compressed.
Nov 14, 2006. 4:03 PMerfonz says:
I saw this on the news awhile ago because college students were using this technique to cheat on tests
Nov 15, 2006. 2:33 PMAlexTheGreat says:
thanks for the great idea.
Nov 14, 2006. 5:10 PMtheRIAA says:
oooooooh
Nov 15, 2006. 11:25 AMJames M says:
whoa whoops. i responded to the comment on the bottom of the list... dum dum
Nov 15, 2006. 11:24 AMJames M says:
the problem with a balloon, though, is the fact that you have to blow up the entire balloon to read the text. If the idea is only to transmit a message covertly, then a balloon is fine. However, if you want the message to be read with minimal detection, a rubber band is more fitting.
Nov 14, 2006. 8:38 PMmodio says:
the pen_is mightier for 400 alex
Nov 14, 2006. 4:54 PMzachninme says:
Smart... Great pictures!
Nov 14, 2006. 4:43 PMmrmath says:
I remember seeing something like this on Zoom's detective show within a show--The Bloodhound Gang--back when I was a kid. They used a walking stick and a leather belt. The belt was wrapped around the walking stick, and then the message was written so one letter was on each wrap of the belt. Since the message spanned several rows around the stick, the message was "encrypted" unless you rewrapped it around the stick.
Nov 14, 2006. 4:54 PMFrenchCrawler says:
They also used to use that technique in wars. They used different sized objects at different stations, so the messages would be useless if they fell into the wrong hands.
Nov 14, 2006. 3:30 PMShark500 says:
try a sharpie on a baloon
Nov 14, 2006. 4:27 PMMurf says:
hehe... good job.. that sounds like it would also work.. plus a balloon has much more surface area than an elastic :P
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:HAKRONE
