So basically, it is a sealed pressure vessel with steam outlets. Hot steam is pumped in (or generated within) and the steam outlets provide a torque based on their perpendicular component to the radius of rotation. You also need some sort of bearing to allow for rotation ;)
Well, pressure vessel could be a fancy name for soda can....
You'll need:
1 Un-opened soda (or other) can
A few feet of fishing line or other thing string
Awl or other hole punching device
4 tea lights
Two magnets and two ball bearings :P
Videos on steps 1 and 3 ;)
Remove these ads by
Signing UpStep 1Prepping the Can
Next twist the top tab around and bend it upwards. Remember the goal is to make a sealed pressure vessel with one outlet for steam. If you break the seal, you'll need a new can and you'll need to start over.
Now (as I discovered in my second attempt), only puncture one hole -- and then slightly dent the can so that the hole points to one side.
because nobody would eat something called butt if it was actually butt. hence rump roast not butt roast...
http://sci-toys.com/scitoys/scitoys/thermo/thermo.html#heat
I'm not married - but my girlfriend (she is my significant other :P) has gotten used to my tinkering, experimenting and overall "meness" :P
check out my new instructable i just made it.
my instructable
Please give credit for this ripoff to
Rob Cockerham.
http://www.cockeyed.com/incredible/hero/hero1.php
Trebuchet's magnetic bearing is a distinct improvement over basic fishing line or string, which twists up and slows the engine, or a fishing swivel (fairly high friction) - I'll pinch it next time I do it for a class.
