Ancient Egyptian Scepters
1,896
32
9
Posted
Introduction: Ancient Egyptian Scepters
Hello everybody! I'm back with my second instructable! These are Egyptian scepters that I made with paper only. (almost!) The first picture I copied the colors, beads and designs from Cecil B. Demille's Ten Commandments. They are very easy to make and it doesn't take very long, either. So, here we go!
Step 1: Things You'll Need
Some sheets of paper
A toothpick
Hot glue gun and glue sticks
Big and small beads of your choice
Medium wire
Scissors
Thick thread
Pencil
A thick coat hanger
Metallic paint or nail polish. (I like the nail polish better because it's so smooth and shiny and it doesn't chip.)
Step 2: Rolling the Paper
Take the first piece of paper and roll it from the corner using the pencil, glue it, and then snip off the ends. Take the glue gun and fill in the ends. Roll the second paper and cut off a small piece and then cut it on both sides as shown in the second picture. Cut it as shown in the third picture and then glue that end to the first piece of paper.
Step 3: The Toothpick
Cut a piece of the toothpick just big enough to fit inside the end of the paper and tie three pieces of string to the toothpick with equal spaces between them. Glue the whole thing inside the end of the piece of paper and let dry.
Step 4: Adding the Beads
Add the beads in whatever pattern you like, but don't tie off the ends.
Step 5: The Ends
Roll three pieces of paper and trim them all the same length. It looks better if you can make them bigger at one end. Fill in one side only. Then bend three pieces of wire and glue them in the other side of the rolled papers. Let dry. Once that is done, tie the ends of the strings to the wires.
Step 6: The Hooked Scepter
For this one the handle is just a piece of rolled paper like the other one. For the hooked part I used a very thick plastic coat hanger. Unfortunately I don't have one to show you, but you should be able to find one somewhere. Just cut off the end of the hanger, put some glue inside one end of the paper tube and stick the hanger inside it. The paint didn't stick to the top very well so I wrapped some thin strips of paper around it and glued it.
For the last step draw equal lines around both scepters and paint each one a separate color.
Step 7: Finished!
So, there you go. Your own Egyptian scepters! I hope I've explained everything to you. Ask me any questions and I will answer all of them. And if you make them please show me your pictures, I would love to see them! Until next time!
    • Trash to Treasure
      Trash to Treasure
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    9 Comments
    It's called a crook and flail, but still nice job!!!
    Is there an alternative to nail polish? Do u know of a way to make these sturdier? I would love to know. PS: amazing work these are so cool! ;-)
    Thank you! Glad you like them! Yes, nail polish does make them a little stronger. But you can fill them with epoxy resin before closing up the ends, or fill them with hot glue. You can also roll two or three pieces of paper, or roll a wooden dowel inside the paper. Oh, and after you paint them, you can give them a clear coat of nail polish or varnish. If you made them good enough, nobody would ever know they were made of paper. :-)
    Your welcome, I would love to come and see your country, it's my favorite place.
    This is cool, nice work.
