Ancient Dwarven Stone Ring (made of Pvc)
2,273
82
6
Posted
Introduction: Ancient Dwarven Stone Ring (made of Pvc)
Hello everybody!
I'll show you how to make dwarven stone ring out of ppr plastic pipe.
I came to this idea when I was bored and I was cutting with my scalpel to the piece of plastic.
Tools and Materials:
You'll need following items
- piece of plastic pipe, that fits to your finger
- scalpels
- sandpaper
- paints
- pencil
- lacquer
that's more less everything.
Cutting
- Before you start, gather all the materials and tools. Just follow all the steps and photos, and I'm sure, you'll be succesful ;) But please, be very careful during cutting!
- At first cut a piece of pipe of desired length
- Then cut off all edges of the pipe with scalpel (be extremly careful, because you can easily loose your fingers!!)
- When you're done, start making deeper cuts from the edges
- After that comes the hardest part. You have to do many cuts all around the pipe to give it carved desing
- As you continue with sculpting the ring will slowly becomes to look like a stone
- You can make some pattern on it and give it a cooler look (I pretty much screwed mine :D )
- When you think you have done enough cutting just sand it a little
Painting
 Now it's time to paint your epic ring!
- You can choose almost every color, but I picked dark brown
- After you painted all the ring, take black color and highlight "shadows". Ring will look more real.
- If you carved some pattern on it, you can highlight it with diferent color as I did. But you should be more precise than I was :D
- To finish it just fix the color with some lacquer and you're done!
You can wear it on your finger or you can tie your hair (or beard) with it like I did! :D
Have fun with making one! Hope you like it!
If you have any questions just leave a comment :)
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    6 Comments
    Great idea, and made from so little... Not that I would diminish the value of a piece of pvc. Thanks for sharing. Now, to get my roleplaying group playing again... And someone to play the dwarf...
    Dwarves rule!!
    Nice, I'm sure that I'm goint to do it!
    Thanks! :) Good luck ;)
    Ah, yes, those two ancient mystical dwarvish elements: mithril and pvc!
