Android Controlled Bot Using Adafruit Motor Shield
Introduction: Android Controlled Bot Using Adafruit Motor Shield
This is a simple hobby circuit of Android Controlled Bot usin Adafruit motor Shield & Arduino uno. The main component used here is the Adafruit motor shield, Arduino Uno, Bluetooth & Android device. Using Motor Shield we can drive two DC motors at 64Khz speed and also can controll the speed. Using Arduino Uno & Bluetooth we can controll the DC motors their directions and speed . The advanced of this circuit is PWM speed controll. You must need an Android Device to controll the bot. Below is the total description of this project.
Step 1: Components Needed
1. Arduino Uno
2. Batteries
3. Battery clips
4. RGB LED's
5. Adafruit Motor Shield
6. Bluetooth HC-05
7. 2DC Motors & Chassis
8. Wheels
9. Connectors
10. Buzzer
11. LED's
12. Cable
13. Android Device
14. Female header
Step 2: Assembling and Connections
Place two geared dc motors on chassis fit it with screws, Connect wheels.
My Arduino having male headers so i solderd the female header to connect the adafruit motor shield. If you are using Arduino Uno then no need of female header. Solder the two blocks of female header on motor shield for 5v and gnd for bluetooth module. Connect all the circuit as shown in the ckt diagram .
Step 3: Programming Arduino
First we need to add Adafruit motor Library. Download it from attachment.
Open Arduino IDE>sketches>include library> add zip library > select zip file of motor library.
Upload the code in attachment to your arduino.
Step 4: Installing Android App
Install the Android App.
Pair your HC-05 bluetooth module.
click on bt icon > select HC-05 > wait 3 sec
Click 1 2 3 4 to vary the speed.
Its done!
Start Enjoying!
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    I cant find the app and everytime I download from your link it links me to an existing different app, please give me a solution because I want to gain more knowledge about serial communication especially in bluetooth so help me ASAP,
    I am using an actual arduino by the way and bluetooth module with 2 rgb LEDs and an adafruit motor shield with 2 dc motors.
    App link is correct. You can download it and connect it with your Bluetooth module to control your bot.
    Where i can find the 5v nd gnd connction on shield for hc-o5?
    5v and gnd holes are given on shield. solder the headers and connect it to hc 05 with patch cords.
    Can I use Arduino R3 instead of your .
    yes u can use arduino r3..
    Which arduino are you using, here?
    it is clone but same as arduino uno..
    Nice share,but where is the app?
    Yes, I uploaded .... Thanks!
