3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Android G1 Serial To Arduino Robot
Step 2Android G1 with serial output enabled
G1's do not ship with the ability to send serial commands out of the USB port and there is no native option to enable it. If you are an advanced Android SDK user you could make your own build but I chose to use the Cyanogenmod 4.2.13. If you know of other Android devices with serial out working, add them to the comments.
Optionally, you can follow the links there to this instructable on talking to your G1 over USB from your PC. That serial to USB connection isn't required for this tutorial but I used it as a nice sanity check to verify the phone was sending serial out.
If you don't use the other intructable to verify serial output is working, you can try this simple check:
1. Open the Terminal app on the G1 (comes with Cyanogen but download one from the Market if you have a different image)
2. Navigate to the /dev/ directory by typing in cd /dev/
3. Type ls (that's an L) and look for ttyMSM2 in the list returned
The Python script we'll use later sends commands to '/dev/ttyMSM2' in order for them to go out the serial connection. Since that requires root access, you'll need to change permissions on that every time you reboot the phone. To do that:
1. Open the terminal app on the phone
2. Enter 'chmod 777 /dev/ttyMSM2'
Then you can run the Python script from the Android Scripting edit in the next step and it will have access to send serial output.
2 comments
Sep 23, 2011. 3:41 AMmahendar says:
i don't see /dev/ttyMSM2 on my phone. It is rooted though. what can I do?
Apr 3, 2010. 5:58 AMwenjiun says:
You can also choose the latest Super D 1.10.2 as well while older version 1.9.3 does not support the feature.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:mranalytical
