Step 4Copy and run the cellbot.py script to launch the Python program
The program creates an open socket connection to accept an incoming telnet session. It also prints the received commands to the screen while sending them out the serial port. Put this file on the phone's SD card in the /ase/scripts/ directory.
Detailed steps to load and run the scripts:
1. Copy the cellbot.py script to the SD card's /ase/scripts/ directory
2. Be sure to dismount the SD card from your PC if you copied them that way since the phone can't access the files at the same time your PC is.
3. Open the Android Scripting Environment app
4. Click on cellbot.py to launch it
You should see a confirmation that the device is ready at this point to accept incoming telnet sessions on port 9002.
Tip: Be sure to run the "chmod 777 /dev/ttyMSM2" command from step #3 first. See step #5 for finding the phone's IP address.
Add Comment
