In this instructable, I go though how to create a mount for a Nexus 7 Android tablet. It's light, cheap, and does what it is designed to do really well. Basically, BEST. ANDROID. ACCESSORY. EVER.
This can also be adapted to fit other controllers and other Android devices.
I made this at TechShop. The tools there really helped make this doable.
http://www.techshop.ws
Step 1: Materials
Hopefully you already have at least these things laying around your house.
Nexus 7 Tablet - $200
PS3 / Xbox controller - $50
For the Mount
1/8" dia x 48" Mild Steel Rod -$3 (OR 1/8" dia x 48" Copper Rod)
48" of 1/8" MDPC Expandable Tubing - Comes in packs of 20' rolls for $7
This is the stuff that people use to manage cables inside of computers. But you want to have a flexible tube that won't scratch your device.
1/8" Heat Shrink Tubing - $2
For some grippy stuff and to clean up the ends.
Tools:
A big vice
bending tools
measuring tape
Step 2: Bending for the Controller
As far as I can thing of there are two ways to attach the controller. By making a clamping U shape to across the back, facing up and across the front, facing toward the device. I'm doing the latter.
1. Bend in half with the end having a small radius. 0.5 to 1"
2. Create a V shape, this will act as a lock for the controller later. (This can be tricky)
3. Bend around the end of the controller and back to the front.
4. Create the opposite V at the end of that. (This V is slighter than the first one)
5. Position the end to be out of the way of the middle buttons on the controller and at the correct angle for the device.
Step 3: Bending for the Device
1. Bend outwards to make a BIG V
2. Measure the correct angle and distance to put the corners of the device inline with that V.
3. Bend up at those points to make the back.
4. Bend forward across the device.
5. Bend down to complete the mount
At this point you should have a lot of extra metal rod. Just cut that off at the proper location and call it good.
Step 4: Softgoods
Then add the heat shrink.
Good locations include:
-The bottom of the controller
-The bottom of the device
-The top of the device
Then use a little bit of heat shrink to close off the metal ends showing.
And your done! You might want to do a little manual bending to get it just right though.
In order to actually play games using the PS3 controller though, you will either have to play games that already are built for wired gamepads and then use a OTG usb cable
OR
Download the Sixaxis app from the app store and emulate the touch controls. This method really opens up gaming options!
Go Play!
Visit Our Store »
Go Pro Today »
Btw, I'm a gamer and an audiophile and I do just fine with an 8gb anyways.
The Razer Fiona is made by "Razer' a company that makes gaming computers and accecories.
They havent made anything that works with PS3 I think.
It looks really cool though!
Mod this so the controller and your hands are beneath the tablet. If you're a serious gamer, you're not looking at your hands anyhow. That might help to reposition the center of gravity, bring the screen closer, and make the whole thing seem lighter. Probably depends, though, on your resting position when you're playing ...
Cool idea, though! Can't wait to get a tablet of my own. One day...
I have questions. How does the controller hook up? is it USB, MiniUSB or what?
And I GOTS to know... what are you using to play PS3/XBOX games on your android???
I too have an 8 gig android 4.0 and just can't wait to hear from you...
Other games might not have that, but do have hardware button mapping. You won't get analog, but it treats the controller as an extension of the hardware. Good for older system emulators.
BUT what you REALLY want is to root your device and get Sixaxis Control. It allows for wireless bluetooth communication between the device and a ps3 controller. It supports the above methods wirelessly AND touch screen mapping. So you map the buttons onto an overlay of the touch controls. This makes EVERY game playable. AND it supports multiple wireless controllers at once! Practically turns it into a portable console.
BTW, that was not a console game, that was Dead Trigger. A free android and iOS game that looks and plays amazing. Technology has come a long way. If you want actual console games on your tablet, check out Onlive.
