Introduction: Android Tablet PS3 / Xbox360 Controller Mount - I Made It at TechShop
Picture of Android Tablet PS3 / Xbox360 Controller Mount - I Made It at TechShop
The new Nexus 7 is a fantastic gaming platform. But for some of use, the holy grail is to have a mobile gaming power with the better controls from a physical gamepad. Touch screen controls can only go so far.
In this instructable, I go though how to create a mount for a Nexus 7 Android tablet. It's light, cheap, and does what it is designed to do really well. Basically, BEST. ANDROID. ACCESSORY. EVER.
This can also be adapted to fit other controllers and other Android devices.
I made this at TechShop. The tools there really helped make this doable.
http://www.techshop.ws
Step 1: Materials
Picture of Materials
Hopefully you already have at least these things laying around your house.
Nexus 7 Tablet - $200
PS3 / Xbox controller - $50
For the Mount
1/8" dia x 48" Mild Steel Rod -$3 (OR 1/8" dia x 48" Copper Rod)
48" of 1/8" MDPC Expandable Tubing - Comes in packs of 20' rolls for $7
This is the stuff that people use to manage cables inside of computers. But you want to have a flexible tube that won't scratch your device.
1/8" Heat Shrink Tubing - $2
For some grippy stuff and to clean up the ends.
Tools:
A big vice
bending tools
measuring tape
Step 2: Bending for the Controller
Picture of Bending for the Controller
The idea is to work from the middle out. Pick the shape that will work best with the controller and the device.
As far as I can thing of there are two ways to attach the controller. By making a clamping U shape to across the back, facing up and across the front, facing toward the device. I'm doing the latter.
1. Bend in half with the end having a small radius. 0.5 to 1"
2. Create a V shape, this will act as a lock for the controller later. (This can be tricky)
3. Bend around the end of the controller and back to the front.
4. Create the opposite V at the end of that. (This V is slighter than the first one)
5. Position the end to be out of the way of the middle buttons on the controller and at the correct angle for the device.
Step 3: Bending for the Device
Picture of Bending for the Device
Starting from the two ends sticking out parallel from the controller part;
1. Bend outwards to make a BIG V
2. Measure the correct angle and distance to put the corners of the device inline with that V.
3. Bend up at those points to make the back.
4. Bend forward across the device.
5. Bend down to complete the mount
At this point you should have a lot of extra metal rod. Just cut that off at the proper location and call it good.
Step 4: Softgoods
Picture of Softgoods
This is just a wire frame. You don't want to scratch your stuff. So take the MDPC tube and cover the entire length with it.
Then add the heat shrink.
Good locations include:
-The bottom of the controller
-The bottom of the device
-The top of the device
Then use a little bit of heat shrink to close off the metal ends showing.
And your done! You might want to do a little manual bending to get it just right though.
In order to actually play games using the PS3 controller though, you will either have to play games that already are built for wired gamepads and then use a OTG usb cable
OR
Download the Sixaxis app from the app store and emulate the touch controls. This method really opens up gaming options!
Go Play!
Blitz7094. (author)2016-04-13
Watching Troy while playing Ryse son of roam.Mobile gaming at its Finest?
Mines is a Arkon c clamp with Xbox one controller
The surface pro multitask gaming
Hey Chung FeiC I have made a Surface Pro 3 holer for my tablet.
Tyejohnson1 (author)2016-01-28
insted of stainles steel
why cant i use zip ties?
Aden8r made it! (author)2016-01-14
Thanks for the idea!
I don't have a vice. I used a couple pairs of pliers for bending. It wasn't easy but it worked. I kept testing the fit on the controller and scratched the controller pretty bad. I couldn't find the tube wrapping stuff in 5 min at Lowe's so I just used electrical tape.
You can see I put a couple extra bends in it so the tablet would be above the controller and hide my hands.
It works pretty good. Not bad for $3!!
robot52 (author)2015-12-21
i love that can you help me make a invengen
Chung FeiC (author)2015-03-14
Do you think it is Possible with a Surface Pro 3. The weight is about 795 gram. Would it be stable enough?
gearup500 (author)2014-11-04
I wish I had an android to use this with.
MoinulA (author)2014-09-19
Thank you ! I prefer DIY than buying :) You sir are brilliant.
xav2075 (author)2014-03-22
Also a generic windows usb pc joypad should work on a android tablet that is not rooted and without an extra android app. But I did have to use a 'otg' usb to micro usb adapter. Search on ebay for 'Micro USB Host Cable Male to USB Female OTG Adapter Android Tablet PC and Phone'. They cost a few pounds\dollars.
xav2075 made it! (author)2014-03-22
I followed this guide to form a wire mount for my Archos Gamepad that has a pair of sub standard in built joypads. I had some difficulty as I did not have the same type of vice in this guide. But with some differences I got the controller mount to fit snugly with the tablet and a generic windows joypad. I used a small square foam pad, often found as feet on computer peripheral boxes, to raise the steel wire above the three buttons that are on the centre of my generic windows pc joypad, so the buttons are not accidently pressed down. Unlike this guide I formed steel wire not to 'hook' over the top of the tablet but I used extra length to form a 'U' shape over the front and back of the tablet with cable ties at the top to brace the wire, covered by clear plastic tubing so the wire wont crack the tablet case at some point, against the tablet. What made it a lot easier is that the Archos Gamepad has 'lips' on the right and left side of the screen for the controller mount to brace against.
InstructableBuddy (author)2013-12-28
my brother ask me to do this because he hate playing in the tablet because its hard to play ckz origins on that
KilMe_Zniper (author)2013-11-28
i will try it too thanks for sharing
jackjackboom (author)2012-09-18
Hate to be a party pooper but they just came out with a playstation gaming tablet that has part of the controller on each side. Its called the Razer Fiona I believe
Also, that is a Windows 8 tablet. We're talking about Android gaming here.
LogTrotter (author)jackjackboom2012-10-04
You are incorrect.
The Razer Fiona is made by "Razer' a company that makes gaming computers and accecories.
They havent made anything that works with PS3 I think.
It looks really cool though!
Farid007 (author)2012-11-05
if you own an ipad what can you do????
billyjoeface (author)Farid0072013-04-04
Get an android?
Atlas Portal 2 (author)2012-12-20
whats the game your playing in the picture
chase32615 (author)2012-11-27
Would a kyros tablet work?
La cacatua carmesi (author)2012-10-20
A question I forgot on the last comment, which free games do you recommend me to play with the ps3 controller, an what app should I download to use it the bluetooth way?
For free games, you can't go wrong with Dead Trigger. It's one of the best games out right now & free on top of that! Modern Combat or whatever they're calling these new combat FPS, is also good. For the bluetooth connectivity, you want Sixaxis Controller by Dancing Pixel Studios.
Gillidog1 (author)2012-09-11
I was thinking about getting the Nexus 7, is it worth it?
madebyjoe (author)Gillidog12012-09-11
Most "worth it" tablet on the market right now in my opinion! Nothing beats that kind of performance at $200. I've even been using it more than my ipad. If you do get one though, do yourself a favor and get the 8gb. You think you need more but unless you are a hard core gamer or audiophile and this is your only device, you don't need more than that. The cloud has got your back.
Btw, I'm a gamer and an audiophile and I do just fine with an 8gb anyways.
Wait a minute... I just bought the Samsung Galaxy Tab p1000, and because it is a bit old for most geeks, I only paid 180$ for it, and it comes with micro sd slot and the best audio quality I've seen on an Android tablet.
Gillidog1 (author)madebyjoe2012-09-11
thanks, im hoping to get one soon
batboy101 (author)2012-10-01
does it work
mikeasaurus (author)2012-08-31
Fun idea! How long can you play before it gets too heavy?
madebyjoe (author)mikeasaurus2012-08-31
About as long as you care to hold a tablet. The controller and mount don't feel that heavy because their center of gravity is nearly inside your grip. With the tablet attached that feeling is less so. It's heavier, but also easier to hold.
rfulcher (author)madebyjoe2012-09-13
Here's a what-if...
Mod this so the controller and your hands are beneath the tablet. If you're a serious gamer, you're not looking at your hands anyhow. That might help to reposition the center of gravity, bring the screen closer, and make the whole thing seem lighter. Probably depends, though, on your resting position when you're playing ...
Cool idea, though! Can't wait to get a tablet of my own. One day...
madebyjoe (author)rfulcher2012-09-13
Now this might be a bit premature here, but I am thinking about going back to the drawing board on this one for some big improvements. Next one will be molded carbon fiber. Super strong, super light, and a snap on design with a little bit of padding. Position of the controller is not for certain though. If it's beneath the tablet, that might pose some interference with range of motion.
dokcal (author)madebyjoe2012-09-13
Might be nice to cut the controller in half and mount each side to the sides of your tablet. Have to run a few wires through the carbon-fiber housing, but I would think the balance would be much better.
littleguy77 (author)dokcal2012-09-24
Heh, I thought of this too. Unfortunately when I cracked open the PS3 and xbox controllers, there were chips all over the middle of the printed circuitboards. The boards had many more traces than I was expecting, so it's a no-go for all but the most insane hacker.
kchapman8 (author)littleguy772012-09-28
Would it work if you kept the board in a sort of "holster"? Or you're saying there's way too many small wires? Cut the controller in half, attach each half to a ratcheting type tablet mount, like you'd get for a car mount. Build a small box that would hold the circuit board, mount eye screws, or something of the like, to the box, and have it ride on the tablet mount" rail". Put wires in heat shrink, or perhaps a coiling wrap. I kinda like that idea. Now, I need someone's spare controller :-)
littleguy77 (author)kchapman82012-09-28
It would be all but impossible to physically cut the printed circuit board and retain functionality. The joysticks are soldered onto the board, but with a little effort could be desoldered and remounted somewhere else. The triggers could also be moved, but they don't come out as a solid unit... usually their hinges and stuff are integrated into the controller's housing... so this would be trickier. For the dpad and buttons, you could buy some aftermarket tactile buttons or something, mount them wherever you like, and solder some wires from the circuitboard to the buttons. With a lot of care you could probably get something decent to work.
dokcal (author)littleguy772012-09-24
BUMMER!
madebyjoe (author)dokcal2012-09-13
I think you're missing the point. The process should be non-destructive.
Ah, I see. We have different points.
About This Instructable
106,241views
272favorites
License:
More by madebyjoe:Arduino powered GLCD (Graphic LCD) - I made it at TechShopArduino Bluetooth Serial Connections! - I made it at TechShopAndroid Tablet PS3 / Xbox360 Controller Mount - I made it at TechShop
Add instructable to:
