Android-Voice-Box [ J.A.R.V.I.S (Artificial Intelligence )]
Published
Introduction: Android-Voice-Box [ J.A.R.V.I.S (Artificial Intelligence )]
About: I aM aN INvEnTor !
"Android Voice Tv Box" is a box containing simple hardware like arduino,bluetooth module,IR-led,T-sop(digital ir receiver ) and a switch. It can provide advantage to control your tv through android mobile by voice inputs, Only You need to say "JASPER" and then speak command channel like "Discovery Channel" and then your "TV" will follow as you says to it.....
The best part of this "BOX" is,It can compatible with all most any TV in the WORLD.
If you want to make your TV More Smarter then follow the steps below and enjoy by speaking commands to your "TV". [I am still trying to add more Channel(s) in the BOX ].
Please Must Share It if u Like Thank You For Marking....! (Please Click ON "VOTE") !
[Note: For control Your Mobile Music Player u Need to first START the Default music player and then pause then open JVC Application then speak commands & Enjoy :::::
Cmd(s) : [ "play music", "pause music","next song","previous song" ]
I have already attached the software. !!
Step 1: Step 1. Prepare Hardware
1.) ARDUINO NANO OR ARDUINO UNO OR ARDUINO MINI OR ARDUINO DUE 328
2.) BLUETOOTH MODULE (HC-05)
3.) T-SOP (DIGITAL IR RECEIVER)
4.) IR-LED
5.) SWITCH
6.) 330E (Resistor)
Step 2: Step 2. Check Bluetooth Name
Note:= The reason for checking the Bluetooth name is, Our mobile software will directly connect to the bluetooth module named "HC-05".
1.) Make circuit as shown in image (only Bluetooth and Arduino)
2.) power up arduino via usb cable or external power port.
3.) In your mobile Turn on Bluetooth and open Bluetooth Settings "Search Bluetooth" and Pair
(Default paswd: 1234) with Bluetooth named "HC-05" (must named as HC-05). If your bluetooth has other name then must be changed to "HC-05". [ To Change Name : Follow this Youtube link:= https://www.youtube.com/watch?v=XaNqa5kP7Cg]
Step 3: Step 3. Make Circuit
1.) Arrange the All Hardware as shown in the figure...!
2.) Download Software Here..
3.) Connect your Hardware to pc
4.) Open Software\ARDUINO\LOADER\XLoader.exe
5.) Select you board, "COM PORT" and upload HEX FILE IN-------[ software / arduino / HEX_FILE / HEX.hex ]
6.) Upload It.
Step 4: Step 4. Config Your Box
0.) Switch off the bluetooth power supply (only).
1.) Open Android_tv.exe in --------- [ software/pc/ARDUINO_TV.exe ]
2.) In Box Setting -> select your arduino port and press connect button
3.) Go to the "Program Remote" Tab.
4.) Press Start Button for programming the "BOX"
5.) Press "0" button from your Tv or Set-top Box Remote .
Note: If u press any button from your remote for long time then may be you will see "FFFFFFFF" in your Code text box! (don't press button for long time)
6.) Then press "SET" button in software At "0." position, You will get Code back in the text box (right side of "SET" button At "0." )
Note: ignore "0" at even number of the code back in At (right side of "SET" button At "0." ) see forth image
7.Full Video:https://www.youtube.com/watch?v=4o9y-iuA_-8&feature=youtu.be
Step 5: Step 5 : Full Config Demo of the BOX
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    • Planter Challenge
      Planter Challenge
    23 Comments
    it was not an artificial intelligence based project its a simple voice controlled arduino based project
    NOT WORKING WITH TATA SKY KINDLY SUGGEST WHAT TO DO!!!!!!!
    can u make a android tv box with arduino?
    Hi , it’s really awesome project thanks so much for sharing ,I want to ask can I add more channels like (mbc , fox ....etc ) because the program unable to add more than 5 channels .
    please sir anwser me soon as you can
    thank you for your great idea
    Amazing instructable.
    Could you please share the droid code?It would be really helpful for me and others to customize it according to our needs. I know it has been developed using Pocketsphinx. I had done something similar but figured out that integrating with Google Speech engine was an easier task. The code you have written is fantastic as the app also listens after you have exited out just like "Ok Google Now". Please share the code if you can :)
    Over all an awesome project and well described.
    Awesome project. would like to see the source code if you are planning to make this as an open source. I want to know more on how to make the mobile software directly connect to the Bluetooth module named "HC-05" using the Appinventor.
    Thank you.
    I would like to see the source for your Arduino code. Is it posted anywhere?
    In Software.zip u will get .HEX
    file I am still working on it .... !
    Seriously though... I may have to consider making this...
    i would like to put entire coding in the next instructable !!
    This looks like a great idea. Although I would make it respond to the name "J.A.R.V.I.S."
    This is great, thank you. How did you make your Android app? Your voice control is very quick and responsive.
