Android Automatic Open Electric Door With QR Code Scan
10,977
68
Posted in TechnologyArduino
Introduction: Android Automatic Open Electric Door With QR Code Scan
This simple tutorial, show you, how to make a simple electric door opener.
No buttons needed.
When you open the app, the phone automatic connect to your arduino via bluetooth,
and scanning the QR code, then open the door for 3 sec, and app closing, disconnect from arduino.
Arduino code in video description.
Part list:
- Arduino nano v3
- HC-06 Bt module
- Relay modul (1 channel)
- Electrick lock (there is 2 type, im use which need power to open)
Thank you..
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    please help me sir
    I try to add the PIR and alarm in your project
    but it doesn't work
    my alarm always voiced
    This is my sketch :
    #include <SoftwareSerial.h>
    SoftwareSerial Blue (8, 9);
    relayDoorlock int = 13; // Relay doorlock at pin 13
    statusRelay int = 0; // Status relay starting with 0
    inputPin int = 11; // Choose the input pin (for PIR sensor)
    int pirState = LOW; // We start, assuming no motion detected
    int val = 0; // Variable for reading the pin status
    pinSpeaker int = 10;
    String ReadString;
    void setup () {
    pinMode (inputPin, INPUT); // Declare sensor as an input
    pinMode (pinSpeaker, OUTPUT);
    pinMode (relayDoorlock, OUTPUT); // Set Relay as output
    Blue.begin (9600);
    void loop () {
    statusRelay = digitalRead (relayDoorlock);
    while (Blue.available ()) {
    delay (3);
    char c = Blue.read ();
    ReadString + = c;
    val = digitalRead (inputPin); // Read input value
    if (val == HIGH) {// check if the input is HIGH
    Playtone (300, 160);
    delay (150);
    if (pirState == LOW) {
    // We have just turned on
    Serial.println ("Motion detected!");
    // We only want to print on the output change, not state
    pirState = HIGH;
    } Else {
    Playtone (0, 0);
    delay (300);
    if (pirState == HIGH) {
    // We have just turned off
    Serial.println ("Motion ended!");
    // Inside Of The Serial Port
    pirState = LOW;
    if (readString.length ()> 0) {
    Blue.println (ReadString);
    if (ReadString == "esvmxrplOa1KIpyn6BRk") // Change the Random string
    digitalWrite (relayDoorlock, HIGH); // Turn on the relay for 30 seconds
    digitalWrite (val, LOW);
    ReadString = "";
    if (ReadString == "CxzJHRO9n1M5OMndUq2T") // Change the Random string
    digitalWrite (relayDoorlock, LOW); // After 30 seconds, turn off the relay
    digitalWrite (val, HIGH);
    ReadString = "";
    // Tell Arduino To Play Piezo Buzzer Tone
    // In msecs duration, frequency in hertz
    void Playtone (long duration, int freq) {
    duration * = 1000;
    int period = (1.0 / freq) * 1000000;
    long elapsed_time = 0;
    while (elapsed_time <duration) {
    digitalWrite (pinSpeaker, HIGH);
    delayMicroseconds (period / 2);
    digitalWrite (pinSpeaker, LOW);
    elapsed_time + = (period);
