Angle Measuring Gadget
Published
Introduction: Angle Measuring Gadget
About: This site is created to share my passion for woodworking and build a community to support beginners in woodworking, like me. For me, the woodworking is fun, inspiring and helps me to design, create and relax.
This video shows how to build angle measuring gadget using dial indicator. This device is best used for truing Table saw blade or other 90° angle measurements. It is simple to construct and calibrate. The dial indicator is available from amazon for $10.99
In the step one I show how to use this nice gadget to square miter saw.
About The Channel This channel is created to share my passion for woodworking and guide beginners into realizing the joy of this hobby. Woodworking is fun, inspiring and helps you to design, create and relax. You can pick up a piece of wood and create something out of it and the result is uplifting. You just created something valuable from piece of wood. The hobby is not cheap and sometimes it is less expensive to buy some piece of furniture then to make it. But this is only true for casual observer, your creations are like work of art, unique, custom and one of a kind. I hope you enjoy the videos and presented projects. Please subscribe to be notified of new projects.
Step 1:
One easy way to square the miter saw is using angle measuring gadget. Using this device we can reliable align the miter saw blade horizontally and vertically.In this video we square Dewalt DW705 miter saw, but any miter saw can be calibrated, squared of with this method.
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    4 Comments
    I could not find a link to the video when viewing on an iPad 2, so I went to YouTube and found the video. As the subscripts mention, this is best suited for checking the saw blade set at 90 degrees. It checks to see if the blade leans nearer to or farther away from the dial indicator pin compared to the reference screws. If the blade is truly set to 90 degrees, the dial indicator will give the same reading from both sides of the blade. I am not sure how to calibrate for other angles.
    The calibration is done at 90°. In the video it is shown that when 90° angle is established on table saw, the readings of the gadget would be same from both sides of the blade. After that you make sure zeroing the Dial indicator and 90° calibration is done! Basically the gadget is self calibrating and you don't need a reference to compare it with. As for other angles, you use the Table saw scale for that. After aligning the table saw to 90°, you align its scale 0°. Then you set it to 5, 15, 22.5 and 30° and take readings with the gadget. Then create a table, plug in the numbers, print and attach to the gadget and you are done. Good luck.
    OK, that was fun to watch but how do you make this "Angle Measuring Gadget?". How do you calibrate it? How do you position it so that it is able to correctly measure the angles? Etc...
    I have yet to come up with drawing and instructions on how to build it. But I can answer your question about calibration. The calibration is done at 90°. In the video it is shown that when 90° angle is established on table saw, the readings of the gadget would be same from both sides of the blade. After that you make sure zeroing the Dial indicator and 90° calibration is done! Basically the gadget is self calibrating and you don't need a reference to compare it with. As for other angles, you use the Table saw scale for that. After aligning the table saw to 90°, you align its scale 0°. Then you set it to 5, 15, 22.5 and 30° and take readings with the gadget. Then create a table, plug in the numbers, print and attach to the gadget and you are done. Good luck.
