3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Angle measurement using gyro, accelerometer and Arduino
The device is a rough prototype of what will eventually become a self balance robot, this is the second part of the hole thing (read accelerometer and control a motor to self balance). The first part with only the gyro can be found here.
On this instructable we will measure the angle using both gyro and accelerometer, and using a technique to merge both sensor to get a smooth signal. The technique is called "complementary filter".
previous
Step 1What we gonna need:
What we gonna need:
Some part can be replace, and some modification at the code have to be made to fit your hardware.
On this project we will use:
- Breadboard
- Microcontroller, I used the Arduinoboard
- Wire
- Jumper Wires
- Gyroscope XV-8100
- Nunchuck Wii (for the accelerometer)
- Nunchuck Wii adapter for Arduino
13 comments
Feb 11, 2012. 1:26 PMontreus says:
Desculpe-me, é que estou construindo um bicoptero e estou com um problema no equlibrio de todo o sistema, estudando seu codigo: angle_for_instructable.pde
Não vi nenhuma linha para a execução dos motores que vc usou no seu robô.
estes comandos estão em um outro arquivo a parte?
Obrigado pela atenção.
Mar 4, 2011. 7:12 PMjgeidl says:
The code link does not link to a .rar but to a .tmp file. Is the code link available somewhere else?
Thanks,
Jim
Jan 27, 2011. 10:53 PMvivekchopra says:
i need to build a human body sensor using an accelerometer and a gyroscope........and i am gonna use labVIEW as software for analysis.....can you please help me with the microcontroller part........should i go with lpc2138???
thanks
Jan 5, 2011. 5:14 PMskeleton1102 says:
Is there any information about how that formula is derived, because I hate using things i dont fully understand
Jan 15, 2011. 7:16 AMskeleton1102 says:
I mean the one to calculate the angle using accelerometers.
Nov 12, 2010. 5:42 AMpaolo.mosna says:
Sorry If i bother you but where can I buy the gyroscope device you used in your realization?
May 17, 2010. 1:53 PMAccentrix says:
Thanks for the explanation. I was waiting for someone to do this.
Nov 2, 2009. 7:28 PMWyoJustin says:
Thanks, I'll need this for my next project.
Justin
Sep 14, 2009. 2:46 AMgellis3000 says:
When I try to download the .rar, all I get is a .tmp file. I have tried 3 different browsers, how does this work?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
31
Author:otaviousp
