Anglepoise GoPro
435
4
Posted
Introduction: Anglepoise GoPro
A while ago I was given an anglepoise lamp. I already have one with a magnifying glass and light.
Although there was nothing wrong with it, it was just surplus to requirements, so I decided that it would make a good stand for a GoPro.
I like to create videos where I am working at a bench and a top down view is ideal.
Step 1: Plan A:
I removed the lamp holder and the wiring and the lamp shade thing.
As luck would have it, I managed to fit a GoPro bracket directly into the pivot point.
The GoPro fitting was about 2mm narrower than the pivot point which I just packed out with a couple of washers.
Attached the GoPro and job done.
It looked a bit weird, but quite a good result really.
Step 2: Plan B:
About a week later I thought that it might be a good idea to have some kind of lighting for the camera.
Fortunately I hadn't gotten around to throwing the lamp shade away.
I had a strip/roll of LEDs that I had used bits of, so after sticking down a GoPro mount, I placed a strip in the inner rim of the lamp shade.
I found an old 12v transformer that was left over from an old router that got replaced, and wired that into the original switch, plugged it in, and I had light, not that bright because the LEDs are not up to much, but a light nonetheless.
I re-attached the lamp shade and fed the wire back through the arms as it was originally.
Step 3: Plan C:
Although it worked reasonably well, I found that positioning the camera correctly was a bit trial and error, due to not being able to see the rear screen of the camera any more.
The lamp shade had air vents in it so I removed a few of the fins, glued the wiring out of the way, and now I have a window through which I can now see the rear screen of the camera.
Step 4: Plan D:
I remember reading about the GoPro App for my phone so I went and did a little research, downloaded the app and started playing.
Following the on screen instructions, I was able to pair my phone to the camera very quickly.
Now I can turn the camera on via my phone and view what it sees without the need to look through the little window that I made.
I can also start and stop recording via the phone so now I don't have to edit out the bits where my hands are in full view pushing buttons on the camera.
Step 5: Done:
I tried to download a video from the camera to the phone and then to my PC.
Yes, it is doable, but takes a lot longer than removing the SD card from the camera and copying the files over manually.
All I have to do now is remember to turn off the wi-fi on the camera to preserve the battery.
This took approximately two weeks to complete, although in reality, it actually took a couple of hours effort.
The video that I created with this setup and have linked to, is for another Instructable that I am in the process of called Arduino Dice
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
  • Sew Warm Contest 2018
Wow, this is a great idea! I'll pick up a lamp myself and try it out. Thank you!
