Angry Balloons: Exploding Blue Bird
 by smurfettesally
This is my version of the exploding blue bird. I was unable to make a video of the making of the balloon animal but I took loads of pictures and hopefully they will be enough along with my instructions. I have also listed a video of stuffing a balloon from you tube. Here: http://www.youtube.com/watch?v=xN5tq-wrCWs They use an air compressor, I used a hand pump and it was a little more difficult but totally doable. You will see that they keep the outer balloon inflated the whole time which is what you need to do if you want to keep structural integrity but since you are going to pop the outer balloon here it does not matter.
Step 1: Gathering your supplies and decorate.
You will need three (3) small light blue balloons, I used 5" balloons. One 9-11" light blue balloon as well. You will also need scissors, a chopstick, skewer (blunt end), dowel rod, or straw, and Sharpies or Galaxy markers, I used a black, yellow, and light orange Sharpies.
Now that you have your supplies it is time to start decorating your balloons. I found it easiest to partially air up my 5" balloons, give a slight twist to the bottom, holding the air in the draw the face on. Next deflate the balloons and stuff them one at a time with all of them already decorated.
I drew the faces on starting with the beak. I used my daughters angry birds bandages container as a rough guide. The blue bird appears to have a simple triangle beak, and sad eyes. I did not take detailed pictures of drawing the faces but I believe I can explain it plus I will include a picture of the drawn face before coloring it in. This is a picture of the large balloon but the face is no different than the smaller balloons.
Draw the triangular beak first, with your orange marker, this was easiest for me. Next draw two round eyes leaving space between them, using black. Next draw a line slightly curved coming from the bottom of the eyes to the beak on both outside and inside, using red. (See picture for explanation on this, I am not sure how to put it into words) Now color in the orange beak and the red 'bags' under the eyes. Once it is colored in let it dry slightly before deflating. (A colored balloon will flake color when deflated.)
smurfettesally (author) says: Nov 3, 2011. 9:11 AM
Thanks!
Penolopy Bulnick says: Nov 1, 2011. 8:44 PM
So cute!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
