3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Angry Birds Level 1-1 Art
This is an easy instructable on drawing the Angry Birds level 1-1.  You will need to draw a red bird, a pig, a slingshot, and the structure.  These are the instructions on how to make them.
Red Bird:
Let's make the red bird.  First, make a big circle, but do not finish the circle at the top.  Instead, place two ovals put together with the  bottoms cut off on the top. To make the tail, place one big rectangle on the bag, and two small rectangles pointing out different ways.  Now, make the eyebrows which are just rectangles.  Place one at a slant and place the other smaller rectangle at a slant the other way.  Place two rectangles right under the eyebrows making the eyes.  Place pupils in the center of the eyes.  Now, do the beak.  The beak is just a scalene triangle at the top and an isosceles triangle attaching to the bottom of the scalene.  To make the bird snicker, place a parallel line to the right side of the isosceles triangle just very close to the corner of the triangle.  Place a big 1/2 oval right from about the lower left side to the lower right side.  Now you're finished with the red bird!
Pig:
He is an oval with one big round circle in the middle for the nose.  Draw nostrils which are ovals colored, and differently shaped.  Draw the mouth which is right under the nose.  Place a 1/2 circle directly at the bottom of the nose.  Now, make the eyes.  The eyes are very simple.  They are just circles, a little bit smaller than the nose.  Draw eyeballs, putting one pupil at the outside border of each eye, making him cross-eyed.  Place the eyebrows, which are just small lines, over the eyes.  Draw very small 1/2 circles on the top of the pig's head to make the ears.  Now you're finished with the pig.
Slingshot:
This is the easiest part.  You just make a rectangle for the bottom and on top of that, make a half oval facing and another half oval inside of that also facing up.  Connect the two halves together at the top.  Make the rest of the slingshot by making two half ovals facing left connecting to the main structure.
Structure:
This part is quite simple.  All you have to do is make rectangles and squares around your pig.  Do the best as you can to copy the level
Now your finished! You might be able to make some more levels like this one.  Experiment!
1 comment
Jul 20, 2011. 1:58 PMpatriots8888 says:
Perhaps you could spend a little bit more time on it. It looks like a five minute project. Try adding color and detaills.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
32
Author:Qtechknow
I'm an 11 year old who has a major interest in electronics and Arduino. I've done many advanced projects and I make my own PCBs.
