Step 5Wiring the LEDs
A cathode connection is the shorter lead adjacent to the flat side of each led.
Using thin,single strand insulated wire (You can use stranded wire instead if you like, although it doesn't look as neat ). Make the connections by carefully striping just enough insulation to wrap the wire around each led lead without completely cutting the wire.
(I used two different colour wires for the anodes and cathodes to make it easier to trace any errors)
Solder each connection as you go.
After making the last connection in a row or column, leave enough wire free for connecting to the pcb which is intended to fit in the space under the centre led.
Do not solder the leads closer than about 5mm from each LED and trim the leads after making all of the connections.
(TIP: Hold each LED lead while trimming to prevent it flying off.)
TIP: If you use small pieces of PVC tape or sticky labels to mark each Row/Column wire it will make it easier to identify when connecting to the PCB.
The trimmed LED leads are sharp, you may want to cover them over later using another similar sized plastic sheet or card.
comments
Add Comment
neilh
says:
Add Comment
