3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Animated 'Haunted' Ouija Board
Animated \
This animated "haunted" Ouija board was made as a Halloween prop. This was made with mainly junk materials from my garage, but if you have none of the parts you should be able to source them reasonably cheaply enough. You need handy-man skills, some electronic know-how, and be able to program a microcontroller or pic (or know someone who can do it for you!)
Update Alert
The board can now say messages sent to it via a serial device - step 12 covers the changes I made!
This is part build-log, part how to. I hope I give you enough info to inspire you to make something similar.
Here is a video of the completed board with the lid off:
And here is a video of the completed box I had ready for Halloween 2007:
New Video
This new clip shows the serial communications link working:
Step 1Stuff you will need
Stuff you will need
A Stepper motor, with gear box, pulleys and toothed belt - I had a set stripped from a dead cheap scanner. You could modify this project to use a braided steel wire or even string instead of the belt, it shouldn't be too hard.
Some wood to suit your design. I messed up when I built mine, and used some poorly finished pine and my not so great woodworking lead to nasty corner joints, which left me needing to veneer the wood with a thin plywood... so keep this in mind, and perhaps use some nice ply to start with, and skip needing to do the annoying veneer finish. Alternatively, you could use the oldest and most worn timber, for that 'ye olde' antique look. Heck, be creative and make it your project!
Something to drive the stepper motor (I'll provide a sample circuit and the microcontroller code) but if you already have something else, or know what you are doing, then knock yourself out, you'll figure it out from the steps I have outlined....
A microswitch for the home position sensor (I got mine out of an old printer)
A power supply (12v 400ma plugpack or 12v worth of batteries if you want it cordless)
Some hookup wire
5 minute epoxy
Items I used but you can substitute with something similar: piano wire, brass tubing, a strong magnet from a broken HDD, brass shim, copper shim, brass split pins, brass box corners, rubber o-rings, scrap aluminium angle stock, screws, small piece of self adhesive felt, hotglue.
Basic tools: Pliers, cutters, soldering iron
66 comments
1-40 of 66next »
Mar 1, 2012. 8:42 PMlucek says:
Just saying this is a Fuji board and planchette. Don't want to get sued.
Nov 12, 2010. 8:06 AMcornetz says:
sir /mam; may i ask for specifications and prize for ur pulleys with diff sizes?thank you very much
Oct 21, 2010. 8:16 AMfrikkie says:
you have great talent at what you build,but I wont build something like that,even though it aint real,the board itself.
Oct 11, 2010. 10:27 PMThekodanator says:
This is an amazingly well written Instructable! Love it!
Oct 10, 2010. 10:55 PMroyblumenthal says:
Wow, Jacob! This is a dazzling piece of invention. Apart from the incredible work you've done on the mechanical aspects, you've clearly thought out the 'psychic' aspect very well indeed!
The pauses, the path the marker makes... very effective in showing that there's a ghost going to extraordinary effort to make that damn thing move! Must be super-freaky to experience!
One piece of 'authenticity' your device has built in is the inability to reach certain letters. Kinda like there's a ghost that can't really spell. Maybe you could put in a 'frustration' loop when it's supposed to hit an 'l' or 'm' or whatever? Something like an agitated motion going to the pentagram, then back to the regular spelling out of the rest of the letters?
Great work!
Blue skies
Roy
Oct 11, 2010. 5:46 AMTreknology says:
If you watch the action of the puck, the builder has incorporated reverse correction so that it does end up pointing at the correct letter. The device is limited by the path of the drive belt. If it were built as an x/y plotter unit instead, then the extra movements that you suggest would be more easily implemented.
I like the way it is now, vaguely shuffling round--definitely enough to freak out a few idiots!
Oct 10, 2010. 10:34 PMktalex says:
does it make a loud racket?
Oct 10, 2010. 6:05 PMjohnet326 says:
This is a great project. Lots of potential for add-ons. Pics are great too. I'm one of the peeps who need to see something to get how it works. I like that the electronics could be used for a robot until Halloween. Thanks for sharing, really enjoyed reading this.
Oct 10, 2010. 10:13 AMphilh77 says:
would be better if you built it into a table and made it not look as thick. maybe just 1/2 inch above the table and the rest built in under the surface of the table, great idea.
Oct 10, 2010. 5:03 PMphilh77 says:
something that fits under the table would be great, I never thought of that.
then use a regular board. I would love to see that.
Oct 10, 2010. 2:01 PMTreknology says:
I love it! You just need to get the noise factor down so that dweebs who really have no f'g idea about this stuff have the $%^& scared out of them!
Oct 9, 2008. 12:57 AMTheInventor says:
(removed by author or community request)
Feb 15, 2010. 7:05 PMgearskin says:
 If you could sink it down into the table, and put mirrors around the outside, people would be floored. They would have no clue. It'd be awesome!
Oct 9, 2008. 4:34 AMawkrin says:
it's a lot more fun to trick people this way!
Aug 27, 2009. 11:04 AMdunnos says:
do you have an overall picture of the setup? i will be making a chess board with my arduino someday soon :)
May 15, 2009. 8:16 AMTED5165 says:
Very well done.
Apr 20, 2009. 6:10 AMznelson710 says:
I am wanting to make one and yours looks all complicated ans stuff. I had the idea to either use an etcha sketch or similar setup. you could replace the knobs with motors and set it doun in the bottom of the box with a raised shaft wiht a magnet. it would be able to reach all the letters and you could increase the speed. just a thought
Oct 9, 2008. 6:25 AMRetroPlayer says:
Jacob, I checked this out last year (still haven't built one though) and thought it was great. With your recent improvements, it is even better. Not sure if you realized it, but you can buy a bluetooth serial converter for $20 on eBay. I have one and they are super easy to use. You just gotta add a bluetooth connection for the full effect. The only other improvements I could think of would be voice recognition software and maybe some simple AI with "personalities" to really get the full effect. If "Alice" chatbots weren't so verbose, that might be an easy way to do it. I don't think people are going to be able to follow the puck for more than a 3 or 4 word sentence without losing interest. I know; always easier said than done. Just wanted to hound you to try it. :)
Oct 9, 2008. 4:21 PMhornbadoing says:
Oct 9, 2008. 5:31 PMRetroPlayer says:
uh... ok... I won't? You can go back to watching your cartoons now. :)
Oct 9, 2008. 8:56 AMRetroPlayer says:
Well, unless you can find something "prepackaged" for the AI and voice recognition, I agree that it wouldn't be worth it. But there are quite a few pieces of software out there that you could experiment with. I think (but I am not 100% certain) that "Alice" is actually configurable enough that you might be able to make it less robust. The neat thing about it being somewhat AI based is that after your initial personality set up, the responses should be a little unpredictable even for you. You just might get goosebumps yourself wondering if 'something else' is guiding it. Just saying it might be worth experimenting a little and seeing what's out there.
Oct 9, 2008. 8:57 AMRetroPlayer says:
Sorry, I meant "..less verbose" not "...less robust."
Oct 4, 2008. 10:44 PMmycroftxxx says:
This project should really go down in history - it has to be fairly unique amongst output devices.
Jun 16, 2008. 10:44 AMsueman2 says:
seems hard to build. i would add it to a huanted house, but for my own i do every year it seems like too much work, and people wouldn't wait around to see it. awsome instructable thoe.
Jun 14, 2008. 7:54 PMbethehammer says:
What is the CD audio input for? did you add a speaker? Nice job on the instructable... and the updates
Mar 24, 2008. 7:18 AMRaisedByRobots says:
gorgeous and scary. just put it in a room with loud music to hide the noise of the motors. impressive.
Mar 24, 2008. 7:20 AMRaisedByRobots says:
ooh, and I am the 13th rater and you have 13 steps. now I am creeped out. I'd better stay inside today.
Feb 7, 2008. 8:37 PMDeusXMachina says:
Very beautiful AND technological. The pentacle is an excellent touch ;-).
1-40 of 66next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:askjacob
Like making things. Like breaking things (to see how they work). Lost many a great toy in my youth to curiosity. Now I feel more confident to put thing back together again...
