3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Animated 'Haunted' Ouija Board
Step 3Build the magnet bracket
Next I built the magnet bracket that attaches to the toothed belt. This was so I could then work out what height the stepper motor and pulleys needs to be mounted in the box. I cut two small pieces of aluminium angle. One of the pieces was been shaped to allow it to securely clamp the belt, yet still smoothly pass over a pulley. The other was cut into a small square.
I then drilled through them both, and used a small bolt and nut to clamp them to the belt.
Next I epoxyed a chunk of strong (neodymium?) magnet broken from a larger flat magnet pulled out of an old hard drive.
I stuck some felt on top of the magnet as a low friction surface.
A note here: you need to use a non-ferrous metal for the bracket otherwise it will cause problems with the magnets - e.g. it will get stuck somewhere, or worse will affect the magnetic field and make the magnet seem weaker.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:askjacob
Like making things. Like breaking things (to see how they work). Lost many a great toy in my youth to curiosity. Now I feel more confident to put thing back together again...
