Step 6Set up a tension pulley
I soldered the third shaft (from previous step) onto some scrap metal (from an old heatsink) with a hole for a pivot at one end, and a hole for a spring at the other. I then used a screw to loosely mount one end, and the other it pulled by some springs (pulled from old pens) to keep the belt tight.
The tension is not very critical at all - you just need enough to make sure it doesn't slip.
Add Comment
