Animated Paper Circuits
6,882
128
11
Posted in TechnologyLeds
Introduction: Animated Paper Circuits
About: I make things, I am curious, and love learning and sharing.
An interactive "live" animation that responds to touch without any programming!
This is a really fun project and could be incorporated into a book or a greetings card, and also e-textiles, or many more surfaces. There are more examples of pieces I have made on my blog: http://blog.beccarose.co.uk/tag/book-art/
You will need:
LEDs (surface mount or other)
3V coin cell
Copper tape
Paper
Binder clip
Adhesive
Soldering equipment /or/ tape
Step 1: Choose an Animated Sequance
You should have as many frames in the animation as you have LEDs. In my example I used 5 frames of a bird flying, and 5 LEDs. Once you have decided what you will animate, draw it onto thick(ish) paper (I have used construction paper in this example, but you could use cardstock), and use a craft knife to cut it out (or use a vinyl / laser cutter if you have one handy!).
Step 2: Fold Your Switch on the LED Page
Step 3: Fold You LED Page in Half
Step 4: Cut Your Frame Page to Size
Step 5: Cut Out Your Frames
Use an craft knife to cut out the animated sequence you chose in step 1
Step 6: Add LEDs
Mark everything out in pencil first.
To get the position of the LEDs, position your frame page on top, and make a small pencil mark at the center of each cut-out frame.
Lay copper tape as in the diagram -note that if you have any breaks in the tape you will need to solder, as most copper tape is only conductive on one side.
Add a small piece of card to connect the battery to the switch. This can be glued or taped.
Step 7: Add Battery and Clip
Step 8: Sandwhich Frames
The LEDs will be at the back, with the frames in the middle, and a blank page at the front...for the magic to happen!
Step 9: Turn Out the Lights and Animate!
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    11 Comments
    That's so cool ! Great job ! :D
    Try adding IR proximity sensors for each LED instead of copper strips , then all you have to do is just hover your hand above the panel.
    good idea -I'd love to know more about how to do this without any progrmaming :)
    Sure ! I've attached the schematic below. My I'ble > https://www.instructables.com/id/Measure-RPM-DIY-Po... covers up IR sensors and will show you how to place the emitter and the sensor. Depending on the type of photo diode that you're using , you might need to increase / decrease the number of transistors. Usually the output of photo diodes is quite feeble and to light up an LED you need NPN transistors to amplify output. Any questions ? I'm all ears. Good luck in the contest ! you have my vote :)
    ohh! thanks so much for sharing! will have a look into this -I really enjoy ways of making things do things without the use of programming (but of course enjoy it when they are progrmmed too!) :)
    Do share the results after you give it a try :)
    This is a fantastic project for kids (with help from an adult of course) to teach them about simple circuits and leds.....very cool and fun! Great job =)
    Thanks! and yes -great for kids, it may also be a good way to learn about frames + frame rates etc. :)
    Woah this is so cool! Love the combination of electronics and prettiness! Nice job, and thanks for sharing!
