3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Animating Multilayered Engravings
Engraving/etching is nothing new but there is always room for new ideas and ways to make them look even better. Back in 2001 when I introduced engraving to the modding community with the Glowpad article (world first lighted mousepad), the basic one colored line drawings were enough to make everyone smile. 2002 saw the introduction of multicolored engravings. It was about time to make them animate and that is what this tutorial is all about.
I'll first introduce the technique with a simple logo and then move on to something bit more flashy.
I have to apologize about the watermarks on the images. The article was originally published on my modding site: http://metku.net/
Step 1Idea
Idea
Getting the engraving to animate involves more than one engraved surface. Basically one just slaps as many sheets of engraved clear acrylic on top of another, as many as the animation requires. Animation is them played by lighting up one layer at the time.
To show the basic princible I selected the Intel Inside logo. It has three distinctive objects that can be divided to separate layers.
Each layer is engraved by using whatever engraving tool you like. I prefer the Dremel Engraver for more detailed work and regular Multitool for larger surface areas.
Impotant note: As we are lighting up one layer at the time, one should try to keep the engravings from overlapping one another if possible. This is not that much of a problem if the image is a simple line drawing but if the topic calls for larger sanded/engraved areas, they will block the light coming from the layers behind them. Just something to keep in mind when selecting the ideas for the image.
51 comments
1-40 of 51next »
Jul 19, 2011. 4:52 PMfmartens1 says:
is there any way to be able to adjust the timing after the resister are installed or possible something to use instead?
Jan 27, 2010. 7:55 PMzapedy says:
 What gauge of wire is used to hook the leds up?
Jul 18, 2009. 6:19 PMneeterxxi says:
A clever and beautiful idea! Quite inspirational for other projects too! With modification, this could make a great faux-neon type sign!
Feb 19, 2009. 7:19 PMDELETED_craz meanman says:
(removed by author or community request)
Feb 20, 2009. 2:05 PMDELETED_craz meanman says:
Feb 22, 2009. 8:38 AMDELETED_craz meanman says:
Jan 1, 2009. 10:59 PMMJTH says:
Haha well, after looking through Acrylic window case modss.. I think I got an even better idea for my window :)
Oct 30, 2008. 3:08 AMCarlos Marmo says:
Wonderful Work! Congratulations!
Sep 27, 2008. 12:22 AMFullyInvolvedScientist says:
This is great! I was just thinking about this in the garage and knew that someone on Instructables would have done it! Great Instructable it has really helped!
Aug 27, 2008. 3:36 PMphoenix124 says:
omg this is just fantastic!! the next computer i do i am so doing this... great idea and great instructable
Aug 25, 2008. 4:20 PMlucasicecream says:
ha i use aluminum foil instead of tape and it worked just fine:)
Aug 10, 2008. 11:25 PMhernanai says:
Favorited! nuff said...
Aug 7, 2008. 8:46 PMbethehammer says:
This is very cool. Nice instructable, very well done.
Aug 7, 2008. 4:38 PMpuffyfluff says:
Cool! I've always wondered how I could do something like this, but this is a perfect way to do it!
Jul 9, 2008. 6:52 PMspacehonkey says:
Very cool idea and easy too. This brings a normally still picture to life. I'm going to have to use this effect myself.
Jun 30, 2008. 2:08 PMdalucero says:
I see that you suggest that the engraving be made on the back side for all layers. Is the difference 'that' noticable? If there were only two layers for example, would it make a difference if the bottom layer was engraved on the front side (facing the viewer) while the top layer (the layer closest to the viewer) was engraved on the back side?
Jun 19, 2008. 7:42 AMMangetout says:
Wow! What a cool idea. The thickness of the layers could also be used as part of the animation effect - for example, imagine each frame of a dancing stick-man animation engraved on a separate layer of acrylic - as the the layers are illuminated in turn, he will appear not only to dance, but to be moving back and forth within the stacked plastic.
Jun 19, 2008. 11:39 AMfrollard says:
I'm not sure what you're getting at - any reasonable number of frames could be any orientation and image size/location...
Jun 22, 2008. 5:23 PMMangetout says:
The plastic has thickness - and you can only really illuminate each layer of it, or not - because of the thickness, the layers will appear superimposed, but it will be possible to discern the Z distance between them. If a 20 frame animation of a stick man was engraved on 20 frames of 3mm acrylic, then these were stacked together, illuminating each layer in turn would appear to make the animation proceed **forwards** through the entire 60mm of the stack.
Jun 28, 2008. 10:30 PMfrollard says:
a person could orient the frames randomly throughout the stack... perhaps even scale the size of the animation as it gets deeper, it gets larger so that it appears a uniform size..
Jun 28, 2008. 2:40 PMLinuxH4x0r says:
Wow, I want to try this!
Jun 24, 2008. 3:15 PMZachB says:
That's Amazing! Do you think you could give me some links to sites about glass engraving so that I might attempt to make one of these?
Jun 19, 2008. 9:14 AMPKM says:
Just a thought- you could use RGB LEDs to change the colour of the "inner" parts of the flame as the "outer parts" light up so the first part to light up changes from (eg) red to orange to yellow while the others light up red. That's a bunch more complexity, though, and I don't know how much the colours would "bleed" between the sheets of acrylic. Top-notch Instructable! (pun not intended)
Jun 23, 2008. 9:54 AMflightsofideas says:
I agree with your "simple" design - you definitely got everyone going "I can go this!" Now you have to deal with us ripping off your idea and adding our own spin (I promise to credit you if I ever attempt a 100 pane laser etched RGB display housed in a 42U rack ;-P ). Keep up the good work at Metku.
Jun 21, 2008. 2:54 PMrc jedi says:
rgb led s would improve an already great idea. cool!
Jun 19, 2008. 4:50 PMtech-king says:
are you the real metku? if so: i honor you! i love your work! if not: phoney!!!!!
Jun 21, 2008. 5:53 AMWhatnot says:
Yeah I have doubts too, and agree that if it's the real metku he's excellent, I always loved the site and build some stuff from it myself in the past :) And if it's not the real one, at least he linked to it and gave the right target audience a good source! Only annoying thing about the metku site is the silly disagreeable EULA to sign up on the commentsystem, like 'if for some obscure reason you fall from grace I'm not just banning you but also calling your ISP' WTF is that all about? It always made me decide to not sign up.
1-40 of 51next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:japala(Metku.net)
