Animatronic Robot - Five Nights at Freddys
Published
Introduction: Animatronic Robot - Five Nights at Freddys
About: Check my youtube channel for more cool stuff. https://youtu.be/OAwq1_9sX9E
This tutorial will give you the different phases in building this project
Check out a Video tutorial on my Youtube Channel. Subscribe and give a thumbs up :)
Step 1: MATERIALS
1. Arduino
2. styrofoam ( you can use foam board or craft foam)
3. Printout of Freddy
4. Glue
5. hot glue
6.popsicle sticks/ Craft sticks
7. 4 Servos
8. 2 pingpong balls white
9. Wooden platform
10. breadboard
11. wires
Step 2: Paste
Glue the print onto the styrofoam. I suggest using foam board or craft foam much better :)
Step 3: Create Frame
Create the frame of the face by creating a T-Shaped figure out of popsicle sticks and craft sticks. Make sure it is strong. Enforce it by adding more sticks onto it
Step 4: Cut
Cut out the face with cutters and smoothen the edges using the tip of the hot glue gun
Step 5: Add Frame to the Platform
Glue the frame to the platform. Add necessary supports to prevent the frame from shaking too much
Step 6: Add Servo
Glue together ping pong balls and servo. Then, behind the face, add the servo right where the eye hole is located.
Step 7: Add Eyebrow Servo
Glue a stick and the servo together just like the picture. Place it right beside the eye. Make sure it is positioned right beside and add popsicle sticks and some illustration board to make the eyebrows. It will go from a 180 degree angle(open) to 90 degree angle(close).
Step 8: Add Servo to Mouth Cutout
Add servo to the mouth cut out and glue it together. Then glue the servo to the bottom frame. Make sure the mouth goes a 160 degree from a 90 degree angle.
Step 9: Connect and Upload Code
  1. Check picture for connections made
  2. Upload the code using ARDUINO IDE
CODE:
#include
Servo Brow; Servo Left; Servo Right; Servo Mouth; int servoPin = 2; int servoPin2 = 3; int servoPin3 = 4; int servoPin4 = 5;
void setup() { // put your setup code here, to run once: Brow.attach(servoPin); Left.attach(servoPin2); Right.attach(servoPin3); Mouth.attach(servoPin4);
} void loop() { // put your main code here, to run repeatedly: Brow.write(150); Left.write(160); Right.write(160); Mouth.write(170); delay(2000); Brow.write(90); Left.write(40); Right.write(40); Mouth.write(90); delay(2000);
Brow.write(150); Left.write(160); Right.write(160); delay(1000);
Left.write(40); Right.write(40); delay(1000);
Left.write(160); Right.write(160); delay(200); Brow.write(90); delay(200); Brow.write(150); delay(400); Mouth.write(170); delay(200); Mouth.write(90); delay(200); Mouth.write(170); delay(200); Mouth.write(90); delay(200); Mouth.write(170); delay(200); Mouth.write(90); delay(200); Mouth.write(170); delay(200); Mouth.write(90); delay(2000);
Step 10: ENJOY :)
Please subscribe to my channel and checkout my other diy PROPS :D
support me in my Patreon. Miggy paras / Prop duster Theory
www.Patreon.com
Paypal
Donate $1 to help me build more projects for you guys :) It would really help me.
Paypal Email: miggyparas15@gmail.com
Checkout my youtube channel as well :D
https://youtu.be/ZhNy46JhXyc
    • Woodworking Contest
      Woodworking Contest
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
