All of this proved to be a pretty tall order but eventually it all came together and now you can make a moving Stargate helmet of your own!
Here's a video of the helmet-
Be sure to click on the photos to download high res images.
Remove these ads by
Signing UpStep 1: Tools and materials
Tools-
Saw for cutting wood/metal- I use a Milwaukee hand saw that accepts reciprocating saw blades- super handy! http://www.homedepot.com/h_d1/N-5yc1v/R-202525764/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Cordless drill w/ various drill bits
X-Acto knife with #11 blades
Scissors- small sharp scissors make cutting the patterns easier
Glue gun
Sandpaper- small piece of 100 grit to smooth wood edges and spackling
Allen wrenches- Inch
Screwdrivers- phillips and flat head
Soldering iron
Ballpoint pen
Bench vise or some other way of securing work while cutting metals
Trusty Instructables multitool- I never leave home without it!
Materials-
Cardstock (2pkgs)- http://shop.hobbylobby.com/store/item.aspx?ItemId=168038
Newspaper
Craft foam sheet (10ea 12" x 18")- http://shop.hobbylobby.com/store/item.aspx?ItemId=160137
White glue
Tacky glue- http://shop.hobbylobby.com/products/clear-gel-tacky-glue-163972/
Gorilla glue- http://www.homedepot.com/h_d1/N-5yc1v/R-100141832/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Spray foam- http://www.homedepot.com/h_d1/N-5yc1v/R-100068117/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Paint- 1 can silver
1 can copper
1 can satin clear coat
Pastels- dark blue, reddish brown, black
Spackling paste- http://www.homedepot.com/h_d1/N-5yc1v/R-202314762/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Plywood- 3/32" thickness, 6" x 12" (3ea)- http://www.micromark.com/Birch-Plywood-3and32-Inch-Thick-x-6-Inches-Wide-x-12-Inches-Long,6909.html
Minwax Polycrylic sealer- http://www.homedepot.com/h_d1/N-5yc1v/R-202061439/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Velcro- http://www.homedepot.com/h_d1/N-5yc1v/R-202261913/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Cotton swabs/ soft brush- for applying pastels
Electronics/Hardware-
Arduino- I used my own design Arduino servo board (you can use any variety Arduino you want- available at RadioShack, Sparkfun, Adafruit, etc.)- http://www.instructables.com/id/Arduino-animatronics-make-your-awesome-costumes-m/
Small switch (2ea)- http://www.sparkfun.com/products/8837
JST female connector- http://www.sparkfun.com/products/9749
JST extension wire http://www.sparkfun.com/products/8670
AA batteries (4ea)
AA battery holder- http://www.sparkfun.com/products/552
Servos- Hitec HS-81 (3ea)- http://www.servocity.com/html/hs-81_micro.html
Hitec HS- 425BB (2ea)- http://www.servocity.com/html/hs-425bb_super_sport_bb.html
Servo extension wire- http://www.servocity.com/html/12__servo_extensions.html
Gears- 22T 32 pitch Hitec splined (2ea)- http://www.servocity.com/html/32_pitch_hitec_servo_gears.html
24T 32 pitch 1/4" shaft mount (4ea)- http://www.servocity.com/html/32_pitch_plain_bore_gears.html
4-40 Swivel ball links (4ea)- http://www.servocity.com/html/4-40x3_16__nylon.html
4-40 threaded rod- http://www.servocity.com/html/threaded_rod.html
Super Duty short control horns (2ea)- http://www.servocity.com/html/306sh_short_single_horn.html
Servo shaft adapter 1/4"- http://www.servocity.com/html/servo_shaft_attachment___250__.html
10-32 Rod end- http://www.markwilliams.com/detail.aspx?ID=1313
10-32 tap & drill bit
10-32 bolt
10-32 nuts (3ea)
1" Aluminum angle- http://www.onlinemetals.com/merchant.cfm?pid=971&step=4&showunits=inches&id=62&top_cat=60
Nylon spacers- 1/4" ID x 1/2" OD- http://www.servocity.com/html/_4_nylon_spacer.html
1/4" OD brass tubing- http://www.onlinemetals.com/merchant.cfm?pid=1539&step=4&showunits=inches&id=84&top_cat=0
3/8" Aluminum rod http://www.onlinemetals.com/merchant.cfm?pid=1082&step=4&showunits=inches&id=195&top_cat=60
Aluminum mounting hubs w/bolts- 1/4" and 3/8" bore http://www.servocity.com/html/set_screw_hubs.html
10mm super bright white LEDs- local supplier or http://www.cablesandconnectors.com/30000-30.HTM
10mm LED holders (2ea) I purchased these locally but I found some online here- http://shop.vetcosurplus.com/catalog/product_info.php?cPath=376&products_id=9026
Resistors- 100 Ohm (2ea) -local Radio Shack
Standoffs- I used standoffs I salvaged from electronics equipmentI found in dumpsters but lots of places sell them online in various sizes -http://www.servocity.com/html/standoffs___spacers.html
Female breakaway headers- http://www.sparkfun.com/products/115
Miscellaneous wire/small wood screws
Small piece of steel sheet- I used a scrap piece cut from old electronics chassis material
Magnet- http://www.kjmagnetics.com/proddetail.asp?prod=DA2
Visit Our Store »
Go Pro Today »
Not that the programmed movement isn't great. I just remember seeing an earlier prototype of yours that used flex switches controlle a MAKE setup and was curious if that was still possible with arduino.
I haven't even begun working with electronics, but I'm looking to make a "simple" (at least I thought when I started) moving head such as this for my first project, but I can't wrap my head around this page's assembly.
Papier-Mache Monsters by Dan Reeder. He has a web site GourmetPaperMache.com
His construction method is very durable. Fast construction.
hmm. in that case, 3 servo then. more natural fluid movement. err. Can you make me head mechanism ? i dont have access to most of the stuff in my country.
Sorry for the late reply!
You could make the helmet move using only two servos- just have it move up/down/left/right and leave out the tilt servo. Having it move in a head tracking fashion is much more difficult because your head really can't move inside the helmet.
thanks for this ible, makes me realize maybe i could make some things like this i have always wanted.
I was most impressed by the head movement. When I saw the video I actually gasped when I saw the falcon head move. Its amazing that you could so accurately recreate bird like movements using only left to right movement plus rotation from the micro servo.
Definitely one of my favorite Instructables. Brilliant!
ears mocked up still working on gears using Lego and craft foam board
still haven't made the face
here are some other projects me and my girlfriend have built thanks to people like you and this great website.
A Serpent Guard, a Horus Guard and a Setesh Guard meet on a neutral planet. It is a tense moment. The Serpent Guard's eyes glow, the Horus Guard's beak glistens, the Setesh Guard's... nose drips.
I don't suppose you've come across other template files for other parts of the costume? such as the gauntlets, (arm bands) boots, and chest plate?
I'd like to throw a complete costume together including chain mail...
http://www.jaffalegions.com/phpBB2/index.php
The complexity and attention to detail in your builds always leaves me... What's the word?... Speechless...
You rock. Thanks for taking the time to document and explain it all so well. That multi-layer craft foam construction is brilliant, and I'm pretty sure I'm going to be using that trick on some of my upcoming robots!
I look forward to seeing your robots!
Great instructable!
but I was expecting it to retract into itself. I kept saying how did they get it to do that. Makes more sense now but very nice.
I also had a bet with a co worker that I could have it ready by Halloween (which I lost) but with my three boys being sick and my work schedule I just couldn't get it done in time. I was falling asleep at the kitchen table at 2:00am while testing the electronics- but I was way too excited about this project at that point to pack it in.
Many more late night build sessions and here it is. Finishing this project was a big deal for me. Just wait until you see what the future brings... :)
This is Hollywood quality stuff...well... Vancouver B.C. quality stuff.
STARGATE LIVES !!!
I working in fiberglass(hobby) I an make 4 pc`s (Casemod), but i dont have working in Arduino, this is amazing!
(ps sorry because off facebook, creat new acount.)
I have done drawings for an opening staff weapon though- it'll require some different construction techniques as it will see a lot more abuse than the helmet.
Yup, I love Stargate too. I've watched 7 seasons of SG-1 too. It's just amazing!
I really liked SG-1 too- have every season on DVD.
Stunning.
Reading back over it there are some confusing parts so I need to do some editing. I also forgot a wiring diagram- oops! It's really simple to wire up but I'll get that fixed later today.
When you did..add a bit more about adding the foam, please. That bit kind of confused me.
But it is still wonderful!!
A work of art!
:D
The spray I understood. Its skinning the sucker that I got lost. Coudlnt you just cut out pieces of foam like you did the original pattern? I dont see laying foam on top..and 'hacking' it out. Not without losing some major details.
:D
Thanks for the info!!
With every added layer (going from folded cardstock to paper mache/spackling to foam skin) you are trying to smooth the surface and reduce the appearance of the fold lines. The foam skin simply gives you a nice outer layer that has a uniform appearance and allows you to put the detail lines in.
