3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Another Altoids Ipod Charger
Alright this is my first Instructable and I made a different version of the Altiods ipod charger. I made my first version off of another instructable but i wanted to make it my own so i made this one
Step 1Materials
Materials
Soldering Iron
Solder
Lots of wires
dremel or something to cut the altiods case
drill
drill bits
9vbattery
9v battery clip
5v Regulator
LED
Resistor (im not really sure which one)
female usb (www.http://www.mouser.com/Search/Refine.aspx?Ntt=806-KUSBX-AS1N-B
this is a pic of the regulator
130 comments
1-40 of 130next »
Feb 11, 2010. 7:18 PMguitarcrazy189 says:
will this work for the ipod touch 3g?
May 6, 2011. 4:09 PM29er sailor says:
Good idea..
Here is something that would work for the touch and iPhone!
http://www.adafruit.com/index.phpmain_page=product_info&cPath=10&products_id=14
Master T
Jul 15, 2010. 3:01 PMhhankpelfreyy says:
sorry man, but from what I've heard, the newer ipod touches and iphones and even the ipad use the data lines to charge in addition to the power lines in a usb cable
Jul 19, 2008. 9:20 PMshantanu007 says:
for some reason this wnt charge my ipone 3g and every thing is wired correctly even the light turns on.
Jul 19, 2010. 3:54 PMCaseBoy says:
you have to connect the the 2 middle pins together.
Jan 7, 2009. 5:58 PMpenuwana says:
dude the iphone uses pin 2 and 3 along with the five volts from 1 and 4, 2 has 2.5volts and pin 3(of the usb or firewire) is 1.8volts look it up 1 found this out too
Jul 19, 2010. 7:36 PMshantanu007 says:
Thanks man this worked for me
Jul 25, 2008. 6:37 PMshantanu007 says:
Would getting a 6v regulator fix the problem?
Aug 26, 2008. 12:28 PMyano says:
usb ports normally put out ~5v, so 6v would probably be too much. I don't know if it would do any damage, but I wouldn't try it personally I've heard that some of the newer iPods require you to ground the circuit, so you might want to try that
Dec 1, 2008. 4:08 PMDYLEGO says:
6v regulator goes to 1v led first, bringing it down to5v
Mar 28, 2010. 12:14 AMtysonscott2002 says:
Just a word of advice to any of you who plan to use that circuit for anything of worth, dont! its not safe enough to charge them with out frying them over time. I have posted one that is basically the same, with some capacitors used as filters, the 330 ohm resistor can be anywhere between 100 and 330 ohms, and the 15k, can but substituted with a 10k, havent tried anything in between!
Mar 28, 2010. 12:18 AMtysonscott2002 says:
Mar 28, 2010. 12:19 AMtysonscott2002 says:
May 26, 2010. 12:57 PMHungryJoe says:
I'm trying to make a USB charger to run off a 7.2v battery (long story), how could/should I adapt your design for this different voltage?
May 26, 2010. 1:54 PMtysonscott2002 says:
well, simply make sure your capacitor (just the one before the regulator, the 100 uf) has a voltage that is higher then your input, for example. if your putting a 7.2v pack into it, those are about 9 volts full, for a new battery, so make sure your capacitor is at least 10 volts or so. after that, just keep an eye on the regulator, the higher the voltage you put in, the hotter it gets, so get a heatsink on it! cause any voltage above that 5 will turn to heat. any other questions, just let me know!
Aug 17, 2009. 5:21 PMbinary_man_1010 says:
the resistor should be a 220(u)-1k(u) the 220(u) color code is a red, red, brown, gold or silver(tolerance) and the 1k(u) is brown, black, red, gold or silver. the perfected one would be thee 220(u) range. the one showed in the picture is a 10(u) resistor and it would burn out the ipod because the voltage would be to high. ~~~binary_man_1010~~~
Mar 31, 2010. 4:36 AMprotonrules says:
errr, no that's not right for two reasons:
Reason 1: resistors resist current not potential difference
Reason 2: the resistor is there to protect the LED and not the iPod its self
Mar 21, 2010. 5:39 PMdylan-drenner says:
 will this one work? radioshack.com and product number is 2062317 thanks bro
Feb 13, 2010. 7:27 PMguitarcrazy189 says:
when ever i made the charger and i plugged my sisters ipod nano 3g in it turned on the ipod on but it didnt charge it and when ever i put my ipod touch 3g into it it did not do anything.  i was wondering if it was beacuse the new ipod touchs are like the iphone and i need to change the wiring.  also i used a 10 ohm resistor, is this to much or too little? someone help!!!
Mar 23, 2009. 1:52 PMpablosartor says:
actually giving less voltage to the regulator by adding the resistor in front might be beneficial so that the regulator does not heat up as much. This works if you are sending more than 5v out of the resistor otherwise it is pointless and agree with bomberman 3 on his circuit. In addition this will not charge your iphone. for the iphone to charge you will need to use pins 2,3 on the usb with a +2.7volts and -2.7 volts in addition to 5 volts on 1,4. Good Luck People : )
Feb 13, 2010. 7:10 PMguitarcrazy189 says:
how would you make it so that pins 2,3 are getting a +2.7 volts and a -2.7 volts?
Jul 13, 2009. 11:40 AMjmcg_ian says:
how would you go about doing this for an iphone?
Mar 31, 2010. 10:53 AMprotonrules says:
this will work exactly the same for an iPhone, they charge in the same way.
Feb 12, 2010. 8:50 AMkdyches17 says:
This does not work for my ipod touch 3rd gen. What would i need to do to it to make it work???? PLEASE HELP!
Feb 11, 2010. 7:13 PMguitarcrazy189 says:
what kind of resistor do yiou need to make the device?
Feb 9, 2010. 7:36 AMtechman9 says:
i have a video nano and when i plug it in it lights up but does not charge, I thought that the ipod cables were wired different, mabe not ge back to me please
Dec 29, 2009. 8:52 AMtomtortoise says:
I made this and used it on a usb light and the led flashed then went away it is not the bulb being burnt out because i can do it again also i nave nano 3g it lights up but no charging.i tried an enV 3 it sais charger not reccomended but starts to charge.
Dec 29, 2009. 5:04 AMxAxrules says:
It's a cool charger, i used this mainly to figure out how to wire up the regulator. I found that the regulator get's warm, I haven't had it on for a long time yet, so I don't know how hot it gets, but I would reccomend a heatsink for the regulator.
Dec 8, 2009. 11:32 AMwassap says:
Thanks Binary Man, you could have just saved my ipod
Dec 7, 2009. 1:00 PMwassap says:
That pic is awesome!. Great instructable too.
Aug 17, 2009. 7:30 PMTarzanJr says:
I forgot to put the resistor in and when i tried it the light bulb blow out so fast but it was very bright next time i am going to video tape it. It was pretty cool!
Dec 6, 2009. 1:56 PMroroanozolo127 says:
i did that and the led blew out so i replaced it but now it wont work
Dec 3, 2009. 3:50 PMroroanozolo127 says:
were can i get a female usb port
Apr 9, 2009. 9:44 AMblzzrd says:
Here is just a better schematic and a few notes about the charger. Required Parts: 1) Toggle Switch – Single Pull Single Throw 1) LED 1) 150 Ohm Resistor (Brown, Green, Brown, Gold) 1) Radio Shack 7805 Voltage Regulator + 5 Volt dc 1) USB Female Cable End Purpose: Toggle Switch – to turn on the charger LED – to indicate the status of the charger (On or Off) 150-Ohm resistor – used to limit the current through the LED and the Voltage Regulator Voltage Regulator – to regulate the output voltage to +5V dc Notes: There is approximately a 1.7 voltage drop across the LED There is approximately a 0.6 voltage drop across the resistor This leaves approximately 6.7 volts entering the regulator The switch, LED, and resistor may be placed in any order because they are in series with each other. All three must be placed between the positive side of the battery, and the input side of the voltage regulator. (A higher resistor value drops the output voltage below the +5V dc output. For example, a 200-Ohm resistor reduces the output to 4.9V dc)
Oct 12, 2009. 2:30 PMAnanand says:
(removed by author or community request)
Nov 8, 2009. 6:58 PMfourier says:
It should have no problems charging an Ipod.  However, Iphones are a different story.  The iphone will "test" the charger by first trying to sink a large current on the data lines.  This is to insure your charger can handle the current that Iphone needs to charge (it has a bulkier battery) If your charger is able to sustain a certain voltage during this sink, it will allow it to charge.  Unfortunately, this configuration cannot charge the iphone.
May 4, 2009. 11:19 PMschmidtty says:
i need some help... i used a small blue LED and i took out the resistor and im using a close to new 9 volt, (about 8.15 v) and im only getting 3.50v out of the regulator. i think my problem is the blue LED is drawing a little less than 4.5v, and that only leaves less than 4.5 v for the output of the regulator... that would explain why i get 4.93 out of the regulator when i put in a brand new 9v. i still want to use the blue LED, but i want this thing to acutally work for more than 5 mins with a new battery. thanks
May 19, 2009. 1:04 AMtonythemediaguy says:
Blue and white both use 3.2 to 3.4 volts. If you MUST use an led (you should really use a green, red, or yellow) then you'll need something like a joule thief and a big resistor to bring the 9 volts down.
1-40 of 130next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:soundman3103
