Another Altoids Ipod Charger
Step 4Wiring the ground
wiring the ground
Solder a wire going from the out of the regulator (pin 3) and solder it to pin one of the usb port.
Take the wire you soldered onto the ground (pin 2 of the regulator) and solder it to the negative of the battery.
Ok now the confusing part. Solder another wire onto the negative of the battery. Take the end of that wire thats not connected to anything and connect it to pin 4 of the usb. Sorry if this sounds confusing
The picture should help a little.
I also tried to make a schematic in paint
16 comments
Feb 11, 2010. 7:18 PMguitarcrazy189 says:
will this work for the ipod touch 3g?
May 6, 2011. 4:09 PM29er sailor says:
Good idea..
Here is something that would work for the touch and iPhone!
http://www.adafruit.com/index.phpmain_page=product_info&cPath=10&products_id=14
Master T
Jul 15, 2010. 3:01 PMhhankpelfreyy says:
sorry man, but from what I've heard, the newer ipod touches and iphones and even the ipad use the data lines to charge in addition to the power lines in a usb cable
Mar 23, 2009. 1:52 PMpablosartor says:
actually giving less voltage to the regulator by adding the resistor in front might be beneficial so that the regulator does not heat up as much. This works if you are sending more than 5v out of the resistor otherwise it is pointless and agree with bomberman 3 on his circuit. In addition this will not charge your iphone. for the iphone to charge you will need to use pins 2,3 on the usb with a +2.7volts and -2.7 volts in addition to 5 volts on 1,4. Good Luck People : )
Feb 13, 2010. 7:10 PMguitarcrazy189 says:
how would you make it so that pins 2,3 are getting a +2.7 volts and a -2.7 volts?
Jul 13, 2009. 11:40 AMjmcg_ian says:
how would you go about doing this for an iphone?
Mar 31, 2010. 10:53 AMprotonrules says:
this will work exactly the same for an iPhone, they charge in the same way.
Dec 29, 2009. 8:52 AMtomtortoise says:
I made this and used it on a usb light and the led flashed then went away it is not the bulb being burnt out because i can do it again also i nave nano 3g it lights up but no charging.i tried an enV 3 it sais charger not reccomended but starts to charge.
Aug 17, 2009. 7:30 PMTarzanJr says:
I forgot to put the resistor in and when i tried it the light bulb blow out so fast but it was very bright next time i am going to video tape it. It was pretty cool!
Dec 6, 2009. 1:56 PMroroanozolo127 says:
i did that and the led blew out so i replaced it but now it wont work
Aug 31, 2008. 11:12 AMbomberman3 says:
I think this would work better for the LED
Jul 21, 2009. 11:50 PMcmart20 says:
I did this with radioshack 9v alkaline battery, spst submini toggle switch, 150-ohm carbon-film resistor, 5mm / 1.7 / volt 20mA / 3000mcd red LED, 7805 5VDC regulator. The female usb that I'm using i got from a usb port and all the 4 metal pins inside came off but I put the pin 1 in and pin 4 back in thinking they are the only ones i need. I finished this project but its not working what did I do wrong?
Aug 17, 2009. 5:26 PMbinary_man_1010 says:
the new ipods are different, yes pins 1 and 4 are the charger but 2 and 3 are also used to tell the ipod that it is charging.(2 is D- and 3 is D+)D=data
Jul 22, 2009. 12:29 PMbomberman3 says:
Are you sure you put the pins in the correct positions? Also, it may not fix your problem, but if you have a 1.7 volt 20 ma led hooked up to 9v (as shown in my schematic), you would need a 390 ohm resistor, not 150.
Jul 22, 2009. 3:12 PMcmart20 says:
yes i did hook the pins correctly because my ipod(3rd gen nano) will be off and when i plug it in it turns on the ipod but doesnt charge it. I was thinking it was the resistor too but i dont know much about them so i didnt know which one to get. thanks ill try it out with a 390ohm resistor.
Jul 22, 2009. 4:32 PMbomberman3 says:
This is a good website for calculating resistor values for your LEDs.
Sep 15, 2008. 4:34 PMKilla-X says:
Exactly what I said before. When the resistor is going to the regulator, your giving it less power than 9V. Thus, like your diagram shows, its best to go a separate path. Also, Your amps question, Radioshack ones are like 1amp, 34V max for input, so I don't know..
Sep 16, 2008. 3:15 PMbomberman3 says:
Ya that's what I was thinking. And about the regulator, I found out that USBs give off a max of 500 mA so a 5v 500mA regulator should work best.
Apr 9, 2009. 8:47 PMpsychodeathmonkey says:
couldnt i just hook up the regulator/9volt jumpers to the input part of the usb cable directly into the device and completely skip the female usb part?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:soundman3103
