Another Arduino Counter
5,647
10
8
Posted
Introduction: Another Arduino Counter
Adaptive reporting parts batch counter
A counter that can adapt to the machine it is fitted to and report data back to other locations e.g. supervisor desk
Here is counter I built as a working prototype for a company I once worked for. This was the second version.
For the first one I used buttons taken from the front of an older “AT” computer case along with LED’s from the same case.
These shields generally have 3 spare DIO’s and 5 spare AIO’s but check your shield as they are not all the same and some have more spares If they are serial based/ i2c etc.
This one has plated through holes on the upper and lower edges that I wired to a distribution block. Soldered mine but recommend using angled pin headers.
Included the text from part of my written company presentation to give you more ideas.
Step 1: Benefits of This Type of Counter.
Capable of sending count data back DIRECTLY to other locations such as supervisor desk for more accurate and reliable part counts with correct configuration.
Can send that count data via multiple methods :- Wireless (multiple frequency options), Ethernet, Serial, GSM or even Local data logging such as SD cards.
Can be mounted in less prone positions than many mechanical counters or even incorporated into many existing electrical panels.
Long term cost savings. As the counter will be mounted “away from the action” its life will be many magnitudes greater than the present mechanical counters. Only the sensors are likely to need replacement but even those will be on a much reduced cycle compared to the present system.
Exceptionally flexible can be programmed to include additional functions on the same board such as machine temperature’s, automated call lights, limited operator monitoring.
Wide +5v to +20 maximum supply voltage. This lends itself to easy integration into many of the existing machines and can also operate via cheap wall adaptors if a reasonable supply is not available.
Cheaper than mechanical counters. Current prototype came in around $30 inclusive of taxes and shipping. The same units can also be obtained or built even cheaper using other options / sources of the same device.
Ability to use “off the shelf components” at very very low cost from suppliers worldwide
Logs and time stamps on logged data will show where and when counters were reset or tampered with. If operators are aware of this they may be less prone to "fudge" numbers which will result in better / more accurate counts.
Should also be possible to add feature to include bar / material type selection resulting in better stock levels of specific parts.
Can be set for either operator (unsecure) or maintenance (secure) increment change for machines that cut multiple parts at once.
Sensor input ( currently shield for demonstration) but easily modified for multiple sources from inductive , capacitive, IR, micro switch, etc. etc.
This program currently set for bar shears with variable increment size ( can accommodate any increment from 1 to 32,767 see above ).
Ability to track total machine cuts / strokes for maintenance & service functions and blade life etc.
Known limitations:-
Upper count limit 32,767 due to 8 bit arithmetic (could use FLOAT to expand counter).
Stuck sensor may continue count but time stamps will show where this happened and this would occur on other electronic counters too.
Can be susceptible to high electrical noise. Must be in screened / metal case in most applications.
Requires power supply.
Step 2: Interfacing
Have had it hooked up to an industrial proxy sensor but that requires its own power supply and can be wired as you would wire a higher voltage / current load.
The output on most industrial sensors is often NOT just a simple on/off pulse but a VOLTAGE pulse so measure yours and add suitable droppers / protection to prevent damage BEFORE you connect it to the Arduino. There are also two, three and four wire variations. I used a four wire and it was harder to interface than a 3 wire which just needed a 500K resistor in the signal line @ 9 volt input to operate the counter.
You should have a decent multimeter if you are going down this route !
If in doubt you can stick to switches or simpler short range PIR / ultrasonic sensors.
For the demo I used it on a local computer and used two programs to set up a quick demonstration. I used “Gobetweeno” and “CoolTerm”
http://mikmo.dk/gobetwino.html
http://freeware.the-meiers.org
These allowed me to capture the data live from the counter and did not require any changes to the program as I already had serial debugging enabled and rather than use the IDE serial screen I just picked the data up from Coolterm.
When it comes to using either of the two programs then rather than go into all the nuances here there is ample documentation on the web sites for those two programs please refer to those. As I said I am quite new to Arduino and I had to use them a bit to get myself going.
The code is heavily documented and a few parts are remarked out as it was either deemed not needed or I did not have the skills to finish it.
If you can make it better feel free
and let me have a copy so that I can improve my skills.
Would love to be able to store and retrieve a few variables in case of a power outage and think I was on the correct path but not clever enough to actually finish it.
Although if you use the “Reporting” side of things it should be easy enough to get the numbers needed back from the reporting computer.
Step 3: Costs and Parts Options
Costings :- updated 12.07.14 **
My first unit was built using an “official “ Arduino, but EBay is your friend and I now have two copies that work just fine. I did run into some issues using a Leonardo due to the way it handles serial communication. This meant I sometimes lost display (blank) at boot up until something changed in the count and then the display would return to normal. So I would avoid those models for the counter.
It is possible as I have done it, to build the same as the one I show for under $6.00
Included the costings as they show how easy it is to build the same counter with options to suit hardware you may already have available. You will have to adapt the code slightly to adjust to differing hardware but it should not be too difficult.
Barest unit including display consisting of 1x Pro Mini atmega328 5V 16M $3.00
** $2.26
Blue IIC I2C TWI 1602 16x2 Serial LCD Module Display $5.00
** $1.99
7 SEGMENT 4 DIGIT DISPLAY (i2C) ** $7.30
(BARE) ** $1.86
TOTAL $8.00
TOTAL 2 ** $4.25
Same as sample unit Arduino Leonardo (updated to UNO) $7.70
** $3.20
Display shield with buttons $6.70
** $1.99
TOTAL $14. TOTAL 2 ** $5.19
Options :-
Power supplies USB derived suit bare unit (cable) $2.00
12V to 5V 3A 15W Car Power DC-DC Power Converters $3.00
Wall outlet to 5V 1A $4.87
Ethernet options with POE (bare board) $
Without POE (bare board) $3.43
** $3.38
With POE (shield) $17.50
Without POE (shield) $8.30
** $5.93
Wireless options NRF24L01+ 2.4GHz Antenna Wireless Transceiver $1.10
** $0.99
433 MHz Transmitter + Receiver Module $1.20
** $1.19
315 MHz Transmitter + Receiver Module $1.30
** $1.28
Bluetooth shield complete $12.00
** $9.89
SIM900 Quad band Wireless GSM/GPRS Shield $32.00
** $21.50
Serial options MAX3232 RS232 to TTL Serial Port Converter Module DB9 Connector $1.70
** $1.65
SD card option SD Slot Socket Reader for Arduino ARM MCU Read and Write $1.00
** $0.82
Data Logger Module Logging Shield Data Recorder Shield for
Arduino UNO SD Card 2 including RTC $6.00
** $5.93
RTC suit bare unit upward $1.00
** $1.45
Many other options are available “off the shelf” to suit other needs. Above is a basic selection only.
Step 4: Code
[code]
R.S.P. Humpleby 2014
Project - Adaptive counter can be tailored to any current machine.
Benefits :-
Capable of sending count data back to other locations for more accurate and reliable part counts.
Capable of shutting down machine at end of run for change over
Can tell operator when end of part run is done saving costs in "over run"
Can be mounted in less prone positions than current mechanical counters.
More reliable.
Exceptionally flexible can be programmed to include additional functions on the same board such as machine tempratures, automated call lights, ethernet, data logging, etc.
Logs and time stamps will show where counters were reset or tampered with.
Can be set for either operator (unsecure)or maintenance (secure) increment change.
Sensor input currently shield for demonstration, but easily modified for multiple sources from inductive , capacitive, IR, microswitch, etc. etc.
This program currently set for bar shears with variable increment size ( can accomodate any increment from 1 to 32,767 see above ).
known limitations:-
Upper count limit 32,767 due to 8 bit arithmatic (could use FLOAT to expand counter).
Stuck sensor may continue count but time stamps will show where this happened and this would occur on other electronic counters.
Suceptible to high electrical noise. Must be in screened / metal case in most applications.
Requires power supply within 10 foot of MCU.
EEPROM write limit 100,000 !!! at which point unit needs program to 4 new EEPROM locations (512 available)
TO DO *****************************************************
Add EEPROM RECOVER for count in the event of power failure
set up bundle size menu
set up increment menu
Revision
1.4 using string array.
Auto set increment to single for machines other than shear (defined by sting order).
Add EEPROM WRITE as per George suggestion
Add EEPROM CLEAR for legitimate reset (probably two points)
1.3 added Andrew suggestion of bundle countdown.
Added routine for pin high at bundle end. operator signal.
Added machine list (array) for future use.
1.2 included down count.
Added count increment and upper lower limits.
Improved serial output.
1.1 basic counter up function and reset only.
#include // Display library
LiquidCrystal lcd(8, 13, 9, 4, 5, 6, 7); // select the pins used on the LCD panel
#include // EEPROM Functions
int bundle = 1000; // bundle size
int nm = 2; // selection of machine 0 = large shear, 1 = small shear etc etc
int lcd_key = 0; // set key initial value
int adc_key_in = 0; // set analog pin for key read
int count = 0; // count from zero
int inc = 50; // set counter increment ********** temp set to 50 for demo only **********
int deb = 300; // 1st debounce / false trigger factor (0.3 seconds)
int del2 = 100; // 2nd debounce / false trigger factor (0.1 seconds)
int led2 = 11; // use 11 as signal indicator for bundle end
int addr = 0; // set up for EEPROM write
int va5 = 1234; // set as an odd count for read back from EEPROM and transfer to bundle not currently used
int bd0 = ((EEPROM.read(0)*4)); // Read bundle value from EEPROM not currently used
int nm0 = ((EEPROM.read(1)*4)); // Read nm value from EEPROM not currently used
int ct0 = ((EEPROM.read(2)*4)); // Read count value from EEPROM not currently used
int in0 = ((EEPROM.read(3)*4)); // Read inc value from EEPROM not currently used
#define btnRIGHT 0 // used to decrement (inc) count steps
#define btnUP 1 // inrement count by ( inc )
#define btnDOWN 2 // decrement count by ( inc )
#define btnLEFT 3 // used to increment (inc) count steps
#define btnSELECT 4 // used to reset counter to zero
#define btnNONE 5 // used for error purposes only
#define endloop 6 // jump to end of bundle routine
#define restart // not yet initiated
// MACHINE LIST (see "nm" variable) You can change these to suit your own needs but I put the machines doing multiple cuts at the front of the list so one cut could be 6 bars which is the basis for the increment count.
char* Str1[ ] = { "LARGE 45 SHEAR ", "SMALL 45 SHEAR ", "STRAIGHT SHEAR ", "PLATE PRESS ", "ROLL FORM ", "SWAGER ", "THREADER ONE ", "THREADER TWO ",
"I/D MACHINE ", "PEELER ", "AUTO PIN ONE ", "AUTO PIN TWO ", "MANUAL PIN ONE ", "MANUAL PIN TWO ", "HEADER ", "WELDER ONE ", "WELDER TWO ", "WELDER THREE " } ;
int read_LCD_buttons() // read the buttons
restart;
adc_key_in = analogRead(0); // read the value from the shield
// my buttons when read are centered at these valies: 0, 144, 329, 504, 741
// add approx 50 to those values and check to see if we are close
if (nm >=3) inc = 1; // if machine not shear then increment = 1
if (bundle <=0) return endloop;
if (adc_key_in > 1000) return btnNONE; // generally no switch triggered
// BAR INC
if (adc_key_in < 50 && inc <= 10) inc = inc + 1 ; // increase bar count step size provided no more than 10
EEPROM.write(3, inc); // Store INC in EEPROM @@@@@@@@@@@@@@@@@@@@@@@@
if (adc_key_in < 50) return btnRIGHT;
// COUNTER INC
delay(del2);
if (adc_key_in < 250) count = count + inc ; // increment counter by "inc"
EEPROM.write(2, count); // Store count in EEPROM @@@@@@@@@@@@@@@@@@@@@@@@
if (adc_key_in < 250) bundle = bundle - inc ; // decrease bundle size
if (adc_key_in < 250) return btnUP;
delay(del2);
//COUNTER DEC
if (adc_key_in < 450) count = count -inc ; // decrement counter by "inc"
if (adc_key_in < 450) bundle = bundle + inc ; // increase bundle size
EEPROM.write(0, bundle); // Store bundle in EEPROM @@@@@@@@@@@@@@@@@@@@@@@@
if (adc_key_in < 450) return btnDOWN;
// BAR DEC
delay(del2);
if (adc_key_in < 650 && inc >=1) inc = inc - 1 ; // decrement bar count step size
if (adc_key_in < 650) return btnLEFT;
// ENDLOOP JUMP
delay(del2);
//RESET
delay(del2);
if (adc_key_in < 850) count = 0; // reset counter
if (adc_key_in < 850) bundle = 1000; // reset bundle
for (int i = 0; i < 3; i++) // clear first 5 bytes of EEPROM
EEPROM.write(i, 0); // clear first 5 bytes of EEPROM
if (adc_key_in < 850) return btnSELECT;
return btnNONE; // in case of error
void setup() // INITALISE
Serial.begin (9600); // Set up serial and remote count using "cool term"
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
lcd.begin(16, 2); // set up the LCD's number of columns and rows:
lcd.setCursor(0, 0); // line 1
lcd.print("JENMAR INC c2014"); // splash screen
lcd.setCursor(0, 1); // line 2
lcd.print("ADAPTIVE COUNTER"); // splash screen
delay (5000); // pause 10 seconds
lcd.clear(); // clear screen
lcd.setCursor(0, 0); // line 2
lcd.print(Str1[nm]); // STD MACHINE LOGO
pinMode(led2, OUTPUT); // define signal on
void loop() // MAIN LOOP
lcd.setCursor(0,1); // move to the begining of the second line
lcd_key = read_LCD_buttons(); // read the buttons
switch (lcd_key) // depending on which button was pushed, we perform an action
case btnRIGHT:
if (inc >=10) inc = 10; // ensure upper limit
Serial.println(Str1[nm]);
Serial.print (" increment = ");
Serial.println(inc);
delay (deb); // debounce and increment counter step + 1
break;
case btnLEFT:
if (inc <=0) inc = 1; // ensure lower limit
Serial.print(" Decrement = ");
delay (deb); //debounce decrement counter step - 1
break;
case btnUP:
lcd.print(count); // display counter plus count
lcd.print(" BNDL>"); // Bundle text
lcd.print(bundle); // bundle count
lcd.print(" "); // trailing spaces
Serial.print (" UP count ");
Serial.println(count);
break;
case btnDOWN:
lcd.print(count); // display counter minus count
Serial.print (" DOWN count ");
break;
case btnSELECT:
lcd.print(count); // display counter back to zero
Serial.print ("***** ");
Serial.print (Str1[nm]);
Serial.print (" COUNTER RESET ***** = ");
for (int i = 0; i < 4; i++) // clear first 5 bytes of EEPROM
break;
case endloop:
digitalWrite(led2, HIGH); // turn the bundle end signal on
lcd.print("> BUNDLE END <"); // splash screen
lcd.print("* CHANGE OVER *"); // splash screen
delay (20000); // pause 20 seconds
digitalWrite(led2, LOW); // turn the bundle end signal off
lcd.print(Str1[nm]); // STD LOGO
lcd.setCursor(0,1); // line 2
break;
case btnNONE:
{ //lcd.print("NONE "); treat as a regular key press
break;
// case epWRITE:
// Write copies of critical variables to EEPROM
// int va0 = bundle / 4; // prep variables for eeprom
// int va1 = nm / 4; // prep variables for eeprom
// int va2 = count / 4; // prep variables for eeprom
// int va3 = inc / 4; // prep variables for eeprom
// EEPROM.write(0, va0); // write to eeprom
// EEPROM.write(1, va1); // write to eeprom
// EEPROM.write(2, va2); // write to eeprom
// EEPROM.write(3, va3); // write to eeprom
// case EPclear:
// Legitimate reset ****** moved to legit reset section ********
// EEPROM clear routine
// for (int i = 0; i < 4; i++) // clear first 5 bytes of EEPROM
// EEPROM.write(i, 0); // clear first 5 bytes of EEPROM
// break;
// case EPread:
// Read and update variables from EEPROM if they exist and are different from either 0 or initial value
// va0 = (EEPROM.read(0)*4); // Read bundle value from EEPROM
// int bundle = va0 * 4; // Set variables using eeprom
// va1 = (EEPROM.read(1)*4); // Read count value from EEPROM
// int count = va1 * 4; // Set variables using eeprom
// va2 = (EEPROM.read(2)*4); // Read machine name value from EEPROM
// int nm = va2 * 4; // Set variables using eeprom
// va3 = (EEPROM.read(3)*4); // Read increment value from EEPROM
// int inc = va4 * 4; // Set variables using eeprom
// break;
// EOF
[/code]
Step 5: Poor Video of Version One!
Was designed for one type of machine but potential was seen for manual counting problems and mechanical counter issues on most of the machines in the plant so it was changed up quickly to suit others.
Counter version one
Feel free to use it as you wish but remember where you found it.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Gluten Free Challenge
6 Comments
Hello,
I just started using Arduino's and micro-controllers, could you please post a simple up down counter that can be reset with the LCD shield? I tried to deconstruct your code, however I keep getting caught up in load errors. Any help would be appreciated, thanks!
The code below should work. I explained I had not implemented the EEPROM routines fully in the instructable and its a very old one. However the code below compiles just fine.
Benefits :-
More reliable.
known limitations:-
Revision
#include <LiquidCrystal.h>
//#include // EEPROM Functions
//int bd0 = ((EEPROM.read(0)*4)); // Read bundle value from EEPROM not currently used
//int nm0 = ((EEPROM.read(1)*4)); // Read nm value from EEPROM not currently used
//int ct0 = ((EEPROM.read(2)*4)); // Read count value from EEPROM not currently used
//int in0 = ((EEPROM.read(3)*4)); // Read inc value from EEPROM not currently used
restart;
// BAR INC
//EEPROM.write(3, inc); // Store INC in EEPROM @@@@@@@@@@@@@@@@@@@@@@@@
// COUNTER INC
delay(del2);
//EEPROM.write(2, count); // Store count in EEPROM @@@@@@@@@@@@@@@@@@@@@@@@
delay(del2);
//COUNTER DEC
//EEPROM.write(0, bundle); // Store bundle in EEPROM @@@@@@@@@@@@@@@@@@@@@@@@
// BAR DEC
delay(del2);
// ENDLOOP JUMP
delay(del2);
//RESET
delay(del2);
//EEPROM.write(i, 0); // clear first 5 bytes of EEPROM
while (!Serial) {
case btnRIGHT:
break;
case btnLEFT:
break;
case btnUP:
break;
case btnDOWN:
break;
case btnSELECT:
break;
case endloop:
break;
case btnNONE:
break;
// case epWRITE:
// case EPclear:
// break;
// case EPread:
// break;
// EOF
Hi Idols,
Can I use Arduino UNO for this one? sorry for the question but Im a newbie and willing to explore on this one. Do you have also the wiring diagram so I can use for reference? Many thanks
Can you help me expand this idea a bit? I want to build a punch
counter for my son's martial arts club. It will count the number of hits
to a punching board (bag) in 45 seconds.
Ideally, what I envision is a reset button, triggering a set of warning beeps......
beep,
beep, beeeeeeeeeeeeeep, a small counting display 1-45 seconds and a
much larger display for the count (3 digits would suffice) followed by a
long beep and stop and freeze the count until the next reset.
Although it might be possible to trigger it with a switch, I think an accelerometer might be the way to go.
I
have all the parts to build, but I am a complete beginner on the
programming side and I could use some help. I want to learn this stuff,
but I need this project sooner than later. ;-)
Any offers to help greatly appreciated!
Best Regards, Dennis
Your best bet is going to be asking over at the Arduino forumshttps://forum.arduino.cc/
There is a project section which is ideal for your task. An accelerometer approach would probably be a better bet as it could also record the force. The timer countdown is the easiest section of code in there and all you need to do is look at the examples section in the Arduino IDE and look at the "blink" example but just use a small piezo instead or as well as an LED.
"// the setup function runs once when you press reset or power the board
void setup() {
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
// define a buzzer pin here
// the loop function runs over and over again forever
void loop() {
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
tone (10,900,1000) ;} //sound buzzer on pin 10 at frequency (x) for (y) amount of time
delay(1000); // wait for a second or whatever time you decide
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
// etc
// rest of code
