3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Another Arduino Laser Tripwire
This is my version of login258's laser tripwire at http://www.instructables.com/id/Arduino_Laser_Tripwire/
I've made a couple of modifications: the laser is now independent from the Arduino so that it can be placed anywhere in the room and I've changed the LED to a buzzer.
LASERS ARE DANGEROUS AND CAN DAMAGE THE EYES. IF CHILDREN ARE USING THIS INSTRUCTABLE ENSURE THEY ARE SUPERVISED BY A RESPONSIBLE ADULT AT ALL TIMES.
Step 1Parts
You will need:
Laser emiter, 3v battery and on/off switch OR Laser pointer and electrical tape
Arduino
Photocell (a big one because it makes an easier target)
2 10k resistors
peizo buzzer
Battery to power the arduino with a jack
breafboard
Various short jumpers
Elastic bands
Blu-tac
Bored kids
Wet sunday afternoon
22 comments
Oct 10, 2011. 9:23 AMdevilmaycry says:
do you when the beam is broken, does the buzzer keep on buzzing or does it tur off after a while
Feb 28, 2009. 7:50 PMLogin258 says:
Thanks for the credit! I'm glad my Instructable actually made some sort of impact. Someone commented on mine and said that two photoresistors would work well, one for ambient light and one for the laser, so that's a good suggestion for you .
Mar 17, 2009. 9:47 PMGreyGriff says:
Mr Login258......I just stumbled onto your little experiment. I have a need and I figured you seemed a lot smarter than I and could tell me if it is possible, how small could the devices be and how much would each cost? I want a laser beam that goes between 20" - 36" or maybe even 48" and when broken makes a noise. I need small....maybe the laser in one section and the "guts" in another place? Cost......are we talking $5, $10, $25 or $50? How do lasers perform outside; wind and sun? My email is rjones.chodrowrealty@gmail.com.........Dinner on me if you can help.
Feb 8, 2012. 10:26 AMakinich says:
why not buy the arduino board and just get atmega's perloaded witht the bootloader.
make your prototype and look up for rrrrrrb arduino
slder the connections and you will have it ready for abt 10 $ max
Apr 28, 2011. 2:55 PMasirota says:
Grey, I spent about 50 dollars on the supplies for this whole project including an Arduino Uno (official version from Arduino) to make this. A green laser could go VERY far, lasers are not affected by wind/sun or anything. My cheap $2 red laser can definitely go about 200-300 fet.
Mar 18, 2009. 7:14 PMLogin258 says:
You could make one pretty cheap. Well really, it depends. For the first one it might cost $50 total, but after that each would be less than $10. Only because the tools needed to program the microcontroller are a bit pricey. Distance isn't a problem, and it could be about the size of a thick cellphone (receiver) with a completely separate battery powered laser unit. And dinner definitely isn't required for my help.
Feb 28, 2009. 10:45 PMinventorjack says:
Another thought is that since this is probably going into a case of some sort, drill a hole in the case for the photoresistor, and recess is into the case a bit so that ambient light is less of a factor.
Feb 20, 2010. 11:39 AMTOCO says:
is there a way to make the buzzer turn off when someone crosses back through the trip wire. That way if it is used for security it wouldn't turn off until the person leaves.
Apr 28, 2011. 2:53 PMasirota says:
Of course there is. The sketch needs to hold a counter in memory that gets switched once and switched again and set the pins appropriately to control the buzzer. Very possible, but the software is different.
Mar 4, 2010. 6:01 PMjm1820 says:
Thanks for the very helpful instructable.
Just wondering, if I could seperate the photocell and Arduino board, by about 20 metres (using wire) ?
Its just that I want to have the photocell at the top of my driveway, and the buzzer inside my house.
I have no idea, if a length of wire, would affect the voltage output of the photocell - anyone have a clue ?
Aug 25, 2010. 12:23 PMdodich says:
Why not place a reflector 20[m] away and keep all the electronics together. Just a thought.
Jul 21, 2009. 4:21 AMgaurangb says:
dear from where i will get circuit for install photosell and buzzer to dedtect beam braking conditions. gaurangb@rocketmail.com
Apr 4, 2009. 10:59 PMjames.mcglashan says:
did u get the arduino at the maker shed or some were else and did u kno u can get an arduino mega it is so good i want 1.
May 28, 2009. 7:26 AMhelloworld1 says:
what are the benefits from the arduno mega to the denou...(dont know its name)
May 29, 2009. 12:43 AMjames.mcglashan says:
it has many more pins and has more other pinsim not an exbert so goto http://makezine.com.com/ for more info
p.s u need to look in the podcasts to find the 1 a little tricky to find
May 29, 2009. 8:49 AMhelloworld1 says:
oh right did not know that thanks
May 30, 2009. 5:06 PMjames.mcglashan says:
May 30, 2009. 5:08 PMjames.mcglashan says:
there is evan a vidio lol
Mar 7, 2009. 8:32 AMamando96 says:
i placed a thermistor instead of the LDR, now i have a very sensitive temperature diference measurer :D next step, get an LCD, and make thermometer :D
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Jonathan Robson
Science museum exhibit design and fabrication manager, stagehand, ballet shoe maker, theatre production manager, project manager and art director of the Beijing Aquarium rainforest exhibit, film extra...
more »
