iImage Information
I needed a smallish desk for a space in my bedroom to last the 8 months or so until I move. I could have done this better, and made it more long lasting, if I'd used 1 1/8" plywood instead of 1/2" MDF, but it's good enough.
Step 1I needed a desk...
iImage Information
It was raining out, and my garage is so messy that I dare not photograph it, so I didn't build this out of a single sheet of plywood and a 2x4, but I could have. Instead I used a 2x3 that I had in the garage and 4 precut sheets or 2'x4' MDF at 1/2" thick. I needed a desk for the bedroom, because I was tired of not having one. I also wanted it to be something that I wouldn't mind throwing away in 8 months when I move 2500 miles or so, since it's crazy expensive to transport heavy/large things that far.
Can I make a couple of suggestions for your final version?
-Yep, drill holes for cables.
-Replace the lamp with LED back lighting behind the edges of your monitor - you are an IT guy after all! :) (wasn't so readily available in 2008)
-To strengthen the front of the desk and prevent bowing, add a strip of wood for support underneath the front and or a facing piece (which will make it look more substantial/expensive too). Incidentally, if you use plywood, facing pieces and hide the sandwich layers and give it a more professional look.
-If you like the look (it is a bit old school), maybe cut the sides on a diagonal, sloping from the top of the back down to the desk at the front. Install a hatchback-style lid with appropriate hinges and latches to keep it open, which hides your gear and or could be a drafting table when closed.. ;)
Keep up the good work ;)
