3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Another DIY Micro-Macro Lens
Step 10Put It All Together
Put It All Together
Put the lens in the upper and gently tighten the set screws until the lens seems tight.
Use rubber bands to hold the whole enchilada onto the camera. I found four small rubber bands worked well, two on each side. The very small screws are your attachment points.
The other objects in the image will be my test subjects.
4 comments
Sep 12, 2009. 2:00 PMstudleylee says:
Good job! I especially like the threaded PVC as a quick adjuster. -Lee
May 31, 2009. 9:04 AMrsw56 says:
Depending on the camera, you might be able to skip the "four small screws" step and simply crisscross the rubber bands placing them as far out as the threaded area, if necessary.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:whiteoakart
It is my personal goal to learn how to do and/or make everything before I die. Just in case there is an apocalypse and I have to do it all myself.
