Step 8Paint the Lens Housing
This helps block scattering of light inside and makes people think you have some mega-expensive lens attached to your camera, instead of some plumbing. If you are particularly mischievous, you might consider adding some white lettering decals with technical-looking numbers and nomenclature for added effect.
Let it dry 24 hours. Flat black paint "looks" dry in about 15 minutes. Don't be fooled.
So, if you can, get a very black velvet piece to line the interior of the lens barrel; but beware, test it to see if it sheds any fiber, because the sensor on digital cameras attract all dust or fibers by electrostatic charge, and not all cameras have sensor cleaning mechanisms!
Good luck.
A small test with etching/frosting spray and black flat paint did prove pretty useful with no worry for the fibers going loose.
I have heard of literally "velvet" sprays but could not find one nor test it.
Thanks so much for the heads-up!
Wonderful instructable as well. Not that it is the first ever DIY macro crash course out there. But the result is rather neat.
If I ever concider giving it a go I think I would try to also purchase a few white letter-a-sets that were out before laser printers were as common.
Thank you for going through the trouble of sharing this with us.
