Step 5If You Build It, Water Will Flow Part 4
After your holes are drilled and you've made up your mind about whether or not to countersink the holes, you're ready to screw the boards together and move on to the next phase of the project. I screwed four of the boards together first to make a frame before adding the two inner pieces for the supports, but it would probably be a bit faster to just attach them to one of your boards and then use the sixth board to close off the box. Your call. You can see by the pics below that there was a little added manual labor in doing it this way.
Your box is finished! Now it's time hack the barrel to allow it to dispense all that free watery goodness!
Add Comment
