Another Quick PCB Prototyping Method
This Instructable is part of my Current Regulated LED Tester
I use this method when I need to make a PCB that's simple, proof-of-concept, and quick. This method is generally restricted to making through-hole component PCBs. I don't usually like to use veroboards because in my opinion, they look ugly most of the time. For more complex, professional looking boards, I normally use the toner transfer method.
The good thing about this quick method is that it still looks decent on the top or component side.
I've looked around Instructables and found a very similar method to mine, but different enough to be significant.
Similar to Real Elliot's Instructable, the key ingredient in this method is, ironically, a veroboard.
Step 1Tools & materials
Tools & materials
- Permanent marker
- Veroboard
- Rotary tool or drill
- Etching tub/container
- Scouring pad
- Copper clad board
- Masking tape (or any other adhesive tape)
- Etching solution
- Acetone
25 comments
Sep 30, 2011. 1:37 AMpopunonkok says:
What? No UV light? Or have i missed something?
Jun 4, 2010. 10:56 AMjaypathak says:
Lovely ! The most simple ..too good
Dec 20, 2010. 3:39 PMJimmy Proton says:
where did you get that etching solution?
Sep 18, 2010. 9:24 PMdarthpotato1 says:
SPOILER ALERT:
The holes that arent drilled are (in coordinates) (12,10) and (15,10)
Apr 29, 2010. 5:24 PMratgod says:
Thats an excellent Idea, I've thought about trying it before but never got round to it, pitty it wont work with SMT devices though.
good instructable
Jun 7, 2009. 10:28 PMappsman says:
Wouldn't it be even easier to drill the holes in unclad board (no copper at all), then push the component leads through, and wire up the underside with un-insulated buss wire? Then you have no etching whatsoever. In fact, for many "traces" you don't even need the buss wire because you can use the component leads themselves by bending them over to make a connection. Don't cut any lead until you see that you won't be using it for a connection. This would look exactly the same as your technique from the topside, is much faster, and requires no chemicals. One more benefit is you don't have to worry about copper traces lifting after repairs or rework.
Nov 21, 2009. 10:59 AMappsman says:
That may be "possible", but in reality it does not happen. You push a component lead through a hole and and then bend the lead to the side. It is very secure. I have made dozens of small boards this way. As long as you are not sending your work up in the space shuttle, the reliability is fine.
Jun 8, 2009. 8:23 AMfrollard says:
he (presumably he) said in one of the steps: perf board looks ugly.
Jul 20, 2009. 1:16 AMcrazyromanian says:
DanZen, where did you buy the etchant and how did it cost? Is there any store I could go to, cuz I kinda hate waiting for mail and paying ship/handling. thx.
Jul 21, 2009. 4:15 PMcrazyromanian says:
sweet thx again. by the way, when you use sharpie as the etch resist, does it not get lifted off the copper cuz I tried http://www.instructables.com/id/The-Saltwater-etch-process/ for etching and I used sharpie and it got removed?
Jul 23, 2009. 2:13 PMcrazyromanian says:
the first time i tried that method, i put only a thin swiping layer with a sharpie that was running short on ink. so mainly the etch resist has to be resistant to water and whatever else is in the solution? and the HCl and H2O2 method looks like the easiest and cheapest I've ever seen, so I'll will try it. thx for the help.
Jun 26, 2009. 3:42 AMvahid_you2004 says:
Good idea for making holes!!!
Jun 14, 2009. 9:34 PMSinAmos says:
Thanks.
Jun 10, 2009. 8:17 PMMiguelReisOrcinha says:
Hey dan, good instructable, I really think it's quite useful but I couldn't help to make a little remark about your routes... In small circuits like this one you can't tell the diference but in bigger ones it's effect is clear. You should avoid at all costs your 3 way knots in the shape of a T, it's considered an circuit board error. you should make some sort of triangle or polygon so that the path that the current as to go is smaller and therefore the natural resistance of the circuit smaller too. you should also try to compact your routes and component to the limit to spare copper and board space. Don't take this the bad way, I'm really only trying to help. in this pic you can see the maker left a lot of copper on the board but that's ok, it helps to dissipate the heat when you solder. he made the polygons im talking about
Jun 8, 2009. 8:09 AMpstretz says:
I really like this idea. I'm for sure using it on my next project. I wonder if it'd be easier to print the mirrored layout with pads and tape it to the board. Basically your method but using paper in place of the perfboard.
Jun 7, 2009. 7:13 AMBongmaster says:
nice :) i use the same etchetant ;) and pen it seems XD tho i have a thinner tip pen for tighter tracks also.
Jun 7, 2009. 10:03 PMGilo says:
Is the green etchant a muriatic acid/hydrogen peroxide mix?
Jun 8, 2009. 6:56 AMBongmaster says:
yup the very same XD
Jun 7, 2009. 9:59 AMdenanderen says:
wouldn't it be easier to first apply your toner and then start drilling the holes? i think it might be easier to drill the holes, because if you drill the holes first, there's a small chance that they don't align with your traces(i.e. by accidentally moving your toner sheet while transferring).
Jun 7, 2009. 12:52 PMMatrixPhreak says:
There was no toner transfer in this, the holes were drilled using a template that was hand-drawn and matches an Eagle CAD layout, then the traces were drawn on the copperclad board with a sharpie marker ontop of the holes. There's no chance of your traces missing your holes unless you physically make the choice to draw them such that they miss.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:DanZen
