3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Another idea for under cabinet lighting
This is my take on making your own under cabinet lighting, also known as kitchen task lights.
I made the task lights from C6 mini LED Christmas lights, bought on "after holiday" special.
I will be using acrylic strips cut from scraps left over from another job to mount the LEDs.
In case anyone is wondering, I am renovating the kitchen as money allows. And since this is a working kitchen, there is bound to be a few things sitting on the counter. Yes, those are custom built cabinets, that I made. To see more of them, check out our website.
Total cost for this project comes in at around $3 per unit, not including the build time. The most expensive part of the system is the $15 universal adapter bought from wallyworld.
Anyway, on with the show.
My first instructable, so have fun with the rating wars for good or bad!
I'll try to answer any questions anyone might have about this or the cabinets. When the weather warms a bit, I will try to put together another instructable showing how I build the cabinetry.
Step 1Harvesting the LEDs
Harvesting the LEDs
This is an example of the type of lights I am making the task lights with.
On these, the teardrop jewel is just pressed into the lamp base, easy to pull apart.
The leads are then bent straight, and the LED removed from the base.
10 comments
Aug 7, 2009. 9:49 AMkansas kate says:
Hey Charlie, Very cool! I have the same problem of needing the strings of lights broken up and not a lot of $$$. Your wife is lucky and you must be a patient soul. Great, detailed write up and pictures. Thank you!
Jun 19, 2009. 5:16 AMhobbygirl45 says:
Ok, this really has nothing to do with the lights. It has to do with the emory cloth. I have a soldering iron that I cannot seem to get tinned. Where did you get the emory cloth and is there a certain grit I should look for? I love the instructable, by the way. Thank you for sharing. :)
Jul 2, 2009. 7:09 AMgafisher says:
Pardon my jumping in, but while emory cloth (sandpaper) will remove the corrosion from a soldering tip, it's also very hard on the plating which should be there.
Two old technician's tricks (from an old technician) might be helpful. First, pick up a "sal ammoniac block" from an electronics parts store, stained glass supply shop, or plumbing supply place. Rubbing a hot corroded soldering tip on sal ammoniac removes the corrosion and restores the tip so it'll take a nice tinning again. Sal ammoniac blocks are harmless and very cheap, and one will probably last most people a lifetime. Second, instead of tinning your soldering tip with the solder you normally use, tin it with solder which has a higher melting temperature, such as silver solder with a high silver content. You might need a torch to get the tip hot enough for the high temperature solder to "take," but once it's tinned with that, the tinning will last *much* longer than when done with your lower-temperature "regular" solder. The best policy is to buy a new tip for your iron, pre-tin that with high-temp silver solder, and then use the sal ammoniac block to wipe off the tip while you're soldering.
Jun 24, 2009. 7:01 PMmissplumeau says:
Nice Instructable! I am re-doing my kitchen and looking around to find clever lighting ideas. I had thought of the LED ropes but I came to the same conclusion as yours. As far as the screw base LED bulbs, I found this a few days ago and will be tinkering with it soon:
http://www.instructables.com/id/THE-LED-LIGHTBULB/
Jan 18, 2009. 5:29 PMRegnar says:
Not to take away from your instructable but you could do the same thing with LED rope light and save yourself a lot of hassle. I did it with my kitchen and the results look the same and they are waterproof.
Jan 17, 2009. 5:29 AMatombomb1945 says:
I got the same coffee cup myself. Always filled too. Must be a job thing or something. Nice Idea and detail. How many of these are you putting up in the kitchen?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:charlie_r
