3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Anti gravity Machine
I like to call this an anti gravity machine, but it could be called a permanent magnet levitation machine. The thing I like about it is kids are fascinated by it.
Step 1First Gather the Materials.
Components
1. Glass or plastic tube.
2. Glue that will stick to glass, plastic, or metal.
3. Button magnets that fit inside the tube.
4. Larger Button magnets to cap the tube.
9 comments
Dec 2, 2011. 4:17 PMlookwhatjoeysmaking says:
its not anty gravity
Feb 19, 2012. 8:15 AMwouternet says:
I can do this better.
Gravity is the force created by 2 objects being attracted to eachother because of their mass in them. Because the Earth is so big, everything is pulled to it's center.
The Moon too is attracted to the Earth. But it stays in it's elliptical path because of it's large momentum created by it's speed.
The tide is created by the Moon, because the Moon's gravity is pulling the seas. The water doesn't leave the Earth because the Earth has a larger Gravitational Force, but the Moon does make it move, creating eb and flood.
What you're just using here is an excellent example of MAGNETIC force overcoming the GRAVITATIONAL force. If you try to hold 2 northpoles together, they will try to push eachother away. This force is created by the 2 magnetic fluxes bouncing into eachother.
Planes use the lift generated by their wings to overcome the Gravitational force... No anti-gravity.
These so called 'Lifters' use high voltages to ionize the air, creating a small airflow. The airflow overcomes the gravitational force. Just like helicopters do. But helicopters use rotating wings, as it is much easier to create enough airflow to lift people and cargo in the air. These lifters use ultralight materials like aluminum foils. Little weight will need little airflow to be lifted from the ground.
To have 'Anti-Gravity' you would need an object that has a greater mass than the entire Earth.
There are no 'gravitons' either. Atoms have mass and mass creates gravity. Particles within (quarks) these atoms have masses. But there is no such thing as Gravitons giving atoms their mass.
And monorails aren't Anti-gravity either.
Nov 13, 2011. 11:03 PMapeacock3 says:
also can you tell me the dimmensions
Nov 13, 2011. 10:45 PMapeacock3 says:
So glu the little magnet to the bigger one.Do you do it north to south south to south or north to north.Please go into detail.
Nov 1, 2011. 3:45 PMiskate4you says:
cool idea. it would be really cool to upscale.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:Josehf Murchison(Josehf Lloyd Murchison)
I am a photographer, a tinker, an electronics technology engineer, and author; I write short stories and poetry for the love of writing. I started writing poetry in high school over thirty years ago w...
more »
