Step 4Construction - Light Bulb Stand
The board that props the light bulbs, and the light bulb platform itself, needed a 45 degree angle cut on side in order for them to bend together properly when the box is closed. I did this using a table router with a 45 degree cutting bit.
Once the boards were cut, I drilled the holes in the main board using a 1 1/4" spade bit. Something to take note of when using these kinds of bits, they are great at cutting nice round holes of an exact size, they are also great at completely tearing up your wood on the reverse side you start on. See the photos below. Fortunately only the top is visible so I didn't really care, although it did make it a little more difficult when mounting the bulb sockets later on.
Add Comment
