Never point these darts at a living being, there is a great risk of bodily harm. This is intended for target practice, or the occasional friendly gam...
You will need to remove the tip of the dart from the foam cylinder. Carefully pull the glue holding the tip on, from around the outside of the dart....
Now that the tip is out, it will need to be trimmed before the new tip is attached. Take your scissors and cut away all of the round part of the tip,...
There should be a small hole at the end of the peg. Simply screw the plastic dartboard tip into this hole, it should be a snug fit so no glue necessa...
Now, take you scissors and cut the foam so that the new dart is the same length as your original dart. Well, that's it. Very easy to do, and a fun ...
Hello again. I was tossing darts at my board the other day when it occurred to me that the dartboard would make an excellent target for me to shoot at. I just needed to adapt my Nerf darts to work with the dartboard. Turns out it's super simple and tons of fun. I'm actually surprised there isn't an instructable about this already. Anyway, here's how I went about refitting the Nerf darts with plastic dartboard tips.
For viewing purposes, the range is very close in this video. In reality I can shoot darts from pretty far away.
Never point these darts at a living being, there is a great risk of bodily harm. This is intended for target practice, or the occasional friendly game of darts ONLY.
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
